Noob question on c of g
Hi all, I have got mysellf a second hand Giles 202 1.5 meter and have a new 46 size engine ect and ime nearly ready for its test flight. When you do the c of g do you have fuel in the tank or do you do it empty! Sory for the question but its been a while since i was up in the air :O) .
Thanks, Brian. |
RE: Noob question on c of g
Empty
Thanks for that http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
Hi bri_on_1
I agree, empty. The reason is that the plane must be capable to be correctly controlled when the fuel tank is empty. This assumes you have a conventional configuration where the fuel tank is in front of the CG. Other configurations may require something else. |
And the only time that this is a moot point is when the tank is mounted at the CG balance point or electrics. :)
| All times are GMT -8. The time now is 04:00 PM. |
