feild box
i was just woundering if anyone has or has seen the carl goldberge monster tote and if they like it or is it to big
RE: feild box
I have the Carl Goldberg Ultimate tote. Is is a bit sparse on space but, fully loaded, gets pretty heavy. The monster tote looks as if it would need wheels to get it from the car to the field. Also, I found the kit a bit lacking in the instructions and quality of materials. I ended up modfiying/replacing many of the stock parts.
Hope that helps, Victor |
RE: feild box
Seems almost not worth buying the kit if you have to replace 1/2 the parts and make your own directions.
RE: feild box
If you're reasonably handy with saw, hammer, and nails.....build your own.
RE: feild box
brent
Although I dont know the sig monster, I would encourage you to get a smaller and lighter model. The way I see, those large totes can carry anything you would need. however, stuff you really need in your everyday flying is just a little. Fuel, starter, battery, glow started, fuel pump, a few replacement props and plugs, voltmeter and a few wrenches (alien, prop), some cleaning material and a couple of screw drivers. Then I would get a second box with everything else you would need, such as: epoxy, ca, duck tape, wrenches, prop balancers, spinners, wheels, chargers, screw drivers, replacemet fuel tanks, screws, bolts, nuts, washers, and so on. Thats just my 2 cents though |
RE: feild box
forgot to mention the plyers
RE: feild box
Your right, the kit was not worth it, and, in hindsiht, I regret not sending it back. Several of the pieces were warped, too short or, in my opinion, too thin to provide proper stability. That being said, the field box, now complete, serves me well.
RE: feild box
An every day tool box from the home improvement store. Works for me! Cheaper, prebuilt, and has pull out tool bins.
A few compartmented storage cases too, for all teh screws and little bits.. Those, with the fuel bottle and starter in a milk crate works troo, and gives you a seat. I've seen one guy use a bucket, with that fancy 'bucket tool box tote' liner thingy.. And a 'radio Flyer' red wagon, to tote all teh stuff in!! |
| All times are GMT -8. The time now is 01:28 AM. |
