Thinning epoxy
I read in a previous post that thinned epoxy is a good way of fuel-proofing the firewall. I just purchased an Avistar, and would like to do this, but have no idea how or what to use as a thinner to thin epoxy. Any help would be appreciated. Thanks Dan.
RE: Thinning epoxy
Dan,
Use either denatured alcohol, or plain rubbing alcohol, whichever you have on hand. Mix the epoxy, then add the alcohol a few drops at a time and mix it in until you have the consistancy you want. Then, just paint it on, and let it sit in a warm place. It may take longer to cure, like a day or two, but warmth will help it cure faster. Don't get it too hot or it will bubble. Just be patient, it will harden up. PS, Welcome to RCU! |
RE: Thinning epoxy
I thin epoxy with Methyl Hydrate; otherwise known as denatured alchohol.. Only a few drops though!!
But some will say that this wil weaken the epoxy, making it porous, like a sponge. Also weakening it, making it flexible. The best methods I found for thinning epoxy, it to heat it. mix it is a cup in a cup of hot water. Like a double boiler.. But remeber, as you heat the epoxy, the cure time decreases! So, 30 minute can turn into 15 minute epoxy! Heat up teh bottles too, in a saucer of hot water.. Also, different manufacturers will have a different consistency. New West Systems epoxy seems to be very runny, ideal for what you're after. LePage's seems to be very goopy. |
RE: Thinning epoxy
I use Alcohol too. Got to the drug store and get the good stuff though, not the cheap stuff.
| All times are GMT -8. The time now is 04:59 AM. |
