RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Muffler Baffle Removal?? (https://www.rcuniverse.com/forum/beginners-85/1138422-muffler-baffle-removal.html)
Ogriv 09-15-2003 02:09 PM
I have an OS 61FX. Would it be ok to remove the baffle thats in the muffler? Could I hurt the engine? Would I loose that backpressure that pressurizes the fuel tank?
Thanks.
Montague 09-15-2003 02:30 PM
RE: Muffler Baffle Removal??
It's a common modification. It makes the engine louder in exchange for a bit more power. There might be a reduction in tank pressure, but I've never heard of it being noticeable. The engine will experience less backpressure, but that's good, that's where the RPM increase comes from.
Ogriv 09-15-2003 03:56 PM
Thanks again Montague for sharing your wisdom.
Ogriv 09-15-2003 05:05 PM
Just an update:
I removed the baffle from the muffler. I also reset the carb back to it's factory setting. I followed all of the advice I found in these forums on tuning my engine. I tell you this engine has come to life! It has so much more power now. I put my tach on the shaft and was reading 12000 RPM with a 12x8 prop. The engine is hotter, but not so hot you can't hold your finger on it for a few seconds.
Many thanks to everyone at RCU that has helped me get my plane flying.
:D:D:D:D:D:D:D:D:D:D:D
