Help
Good afternoon , I was putting my electronics in my plane and needed to know with my alerons when I move my control to the right does the aleron on the right wing move up or down? If anyone could help before I crash another 3 week project please let me know soon thank you .
Move the stick to the right and the right aileron should go up.
Get an experienced r/c pilot to pre-flight you and trim the model; maybe give you a few lessons. It will save you a lot of money. |
Great advice!
Bob |
Originally Posted by Charlie P.
(Post 11826491)
Get an experienced r/c pilot to pre-flight you and trim the model; maybe give you a few lessons. It will save you a lot of money. one minor thing... stand BEHIND the airplane when checking! move the aileron stick (right hand stick) to the right, and the right aileron should go UP. |
Originally Posted by jbbabyiii
(Post 11826490)
Please don't tell me the airflow pushes the wing down
Nope. Airflow has to be faster on the upper surface of the wing with the flap down and it rises because of Mr. Bernouli's theorums (faster air over the surface = lower pressure). However, the flap also creates drag and there is adverse yaw as the wing with the up aileron continues on at a faster rate; twisting the aircraft towards the lower aileron side. In short, heavier than air flight is impossible. ;-)
Thanx Charlie my faith has been restored
| All times are GMT -8. The time now is 01:19 PM. |
