RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   phenoix 2000 issue with assembly rear control rods (https://www.rcuniverse.com/forum/beginners-85/11600578-phenoix-2000-issue-assembly-rear-control-rods.html)
ohiowoodsrider250r 06-22-2014 05:05 PM
hi people i have had this glider sitting in my basement for a year now because the 2 control rods that connect to the hinges for the control surfaces are to short to connect. in fact i'd need to have the server horns facing all the way back to the rear most position to connect them. has anyone else faced this issue? complete newbie to flying here ...i just gave up seeing no solution nor a path to a solution so ..there it sits brand new otherwise ready to fly for over a year . also i read the stock plastic hinges will just break easily can someone tell me a good upgrade for the control surface hinges....and also what props fit on the stock motor?
jester_s1 06-22-2014 07:44 PM
Making control rods is a pretty straightforward operation. But if these were part of an ARF package, maybe you put the servos in the wrong way? DuBro plastic control horns are strong enough for moderately sized glow models, so they'll do fine for your glider. Your manual should have the right prop recommendation.
ohiowoodsrider250r 06-22-2014 08:12 PM
it was rtr all the electrics came pre installed and the only way the control rods reach the hinges puts the control surfaces at full locks
jester_s1 06-23-2014 05:07 AM
Would turning the servos around 180 degrees fix the problem? You will probably notice that the output isn't in the middle of the case, so it will make roughly a 1/2 inch difference to turn it around. It's possible that the factory worker who built your plane put them in backwards, and it's also possible that the wrong pushrods were set with your kit. Both are easy solutions.
bruce88123 07-16-2014 10:50 AM
http://www.hobbyking.com/hobbyking/s...ider_pnf_.html
ohiowoodsrider250r 07-20-2014 01:03 AM
thats the one i have...total waste of money.
AMA 74894 07-22-2014 07:42 AM
it should be a very simple matter (although absolutely shame on hobby king) to replace the pushrods and Clevises (it's the crappy clevises, NOT hinges that are bad on that airframe.)
you may be able to use the existing pushrods by simply turning the servos 180 degrees (putting the servo arm closer to the rear of the aircraft.)
looks like a 10X6 folding prop is what they recommend.
there are a good number of you tube videos for this airplane, like most of HK's stuff this airplane needs a little work to make it flyable.
https://www.google.com/search?q=hobb...x-a&channel=sb
good luck and keep us posted :D
