RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Check before flight (https://www.rcuniverse.com/forum/beginners-85/11604042-check-before-flight.html)
jetmech05 09-13-2014 02:04 PM
Check before flight
I can't tell you the number of crashes, I've seen or heard about, that could have been avoided if a simple control throw check before flight had been accomplished. Today a maiden flight didn't go so well. Ailerons were reversed.
take the time to stand behind your airplane and say to yourself aileron up in the direction I move the stick. Then it's elevator up with stick back. Elevator down with stick forward. Finally rudder moves in the direction of the stick.
Please do this before your first flight of the day. It'll save you an airplane some day
FLAPHappy 09-13-2014 03:07 PM
+10 Jetmech. it only takes 2 minutes to do this, and also check battery voltage and pushrod connectors and landing gear. Don't forget to put in wing bolts if your aircraft has them. Just doing these simple checks will save you a lot of time and money, also avoiding the possibility of injuring someone or yourself.
ml82232 09-13-2014 03:13 PM
It looks silly but I have a piece of tape by the battery switch just says ALL CHECKS
CARS II 09-14-2014 08:08 PM
Sorry for your lost, I have seen it happen before.
blvdbuzzard 09-14-2014 08:24 PM
Guilty as charged. I hate to say this, but I have done it many times over the years. I now move the Tx in the direction of the stick, them compare how the Tx is moving to what I see the control surfaces are doing. I have caught it a couple times now. In my defense, I had the battery for the memory of the Tx die and did not know it. Took me a while to figure out why every time I flew my Ugly stick I had to reverse the ailerons. I was just lucky the other 3 planes had no reversing on them.
Brother calls me the reversed aileron King!!. So When in doubt I have him check it.
Buzz.
jetmech05 09-15-2014 04:35 AM
Wasn't my plane Cars I I I'm just advising.
Carlos Murphy 09-17-2014 05:31 PM
Preventing a crash.
I use VOLT-CHECK'S in most of my planes usually mounted in the cockpits.
One saved my World Models GS P-51, after tuning the Saito 180 for the maiden flight, I was ready.
Moved the plane to the hot-pits for start up, ready to taxi and noticed the red light in the cockpit, battery near dead, had one dead cell.
Volt-Check saved the plane.
