LIFE charger question...
Hi, I have an Imax B6 charger which states that it is LIFE compatable but I think it uses the LIPO setting. Is this charger ok for LIFE battrries, or do I need another brand charger?? If so, any suggestions?? Thanx, Fast....
If it's LIFE it should have a LiFe or A123 setting
http://www.ittgroup.ee/files/IMAX_B6_manual.pdf Page 10 shows that you can select LiPo, LiIon, or LiFe |
I have the same charger and charge my Life battery's on it. The instructions are poor and hard to figure out so you have to experiment somewhat, Just keep going thru until you find the Life
program window, then the settings being sure you set the proper voltage, etc.. It takes a little time to learn but works well for me and I am not an expert! (for sure) |
| All times are GMT -8. The time now is 07:38 AM. |
