I ended up getting a NiMh battery with the equivalent specs except it has Higher MAh rating. I wasn’t sure what the servos inside the plane could handle cause they are a little older so I figured safe bet would be to get get another 4.8v which I couldn’t get in LiPo. also, for my war bird do you guys have any servos you’d recommend? I was looking around on amazon and was going to order some but I didn’t want to order a junky set that would cause my plane to go down. |
Originally Posted by Geakist
(Post 12525088)
Stick with the established brands- Futaba, Hitec, JR, Savox, Spektrum. There are people using some of the newer, cheaper brands like Turnigy and Solar with good success, but the cost savings is pretty minimal compared to the risk IMO.
Current servos in my trainer plane are JR, which I personally have never heard of. Aside from quadcopters I’m new to rc stuff. Quad copters don’t typically use servos, at least for flying. The receiver was Jr but I have a turnigy 9x transmitter so I put a turnigy reciver in the plane. I had assumed turnigy was a decent brand but I’ll defintaly look for some more jr servos instead. These ones seem old but work perfect when I test them with my transmitter. I’m waiting on the battery to come in tomorrow so I can test every thing out again. I took my 9x transmitter apart to switch the throttle stick around to match the one I’ve been using on my simulator. So instead of throttle being right stick on my transmitter it is now the left stick. |
Alas, JR is/was a good brand until recently when they went under. However, I've heard rumors of them coming back. Bottom line is they're in flux as a company right now so I'd use what I have but at the moment I wouldn't purchase anything new from JR.
Mixing equipment brands is OK as long as you know what you're doing. Any Receiver will NOT talk to any Transmitter. Their modulation schemes must match. Terms like DSM, DSMX, FASST and others are the mod schemes I'm talking about. A rule of thumb would be to pick one of the schemes and stick with it. Usually whatever dominates at your local club field. Turnigy came out several years ago as an inexpensive alternative to JR, Spektrum and I even think Futaba. I've never used one and can't comment on their quality. But my impression is they're a second tier brand of radio. i.e. something to buy when you can't afford better. Not bad but not the best. All servos are pretty much interchangeable brand wise. You have to pay some attention to voltages and wire order and such but in general, it's no big deal. However, as mentioned quality can vary. You pretty much get what you pay for! So you may want to avoid the $9.98 jobs. One thing I will do is keep all servos in a given model the same brand. I do not mix brands of servos in a given model. There were some issues many years ago (1980) where a certain brand of servo could not be used with other brands as it would "Sometimes" cause problems. Maybe! I don't think it was ever really determined what caused the issues but I just made a personal rule back then to keep servo brands matched in a given model. One place I like for info if nothing else is Servo City. Link You can research the specs on a lot of servos here. They push Hitec which I've found to be a decent servo for most applications. But like everything, some people don't like them. And like everything, you can get a bad product now and then. Always test your servos in a model you can afford to lose. A big/expensive model I would go with something else however. Another couple of good servo links: Servo Database And: Servo Wiring |
JR Propo is alive and well. They are now distributed by Dee Force Aviation. https://www.deeforce.net/ |
| All times are GMT -8. The time now is 06:16 AM. |
