RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   oil problem (https://www.rcuniverse.com/forum/beginners-85/11689464-oil-problem.html)
kumkumking 04-16-2021 11:53 AM
oil problem
hi
i have a twin engine mosquito and oil is collecting in the manifold of one of them and the other engine there is no oil
collecting in the manifold but the oil is dripping out of the prop shaft so it must be collecting in the engine itself is their
something wrong with the engine,as im led to believe its ok for oil to collect in the manifold-kind regards-the kum
Retiredat38 04-23-2021 04:16 AM
Assuming these are typical RC 2 or 4 stroke engines, the fuel contains some 18% oil give or take. Very little if any of the oil burns. Therefore it has to go somewhere. So what doesn't get blown out the exhaust tends to find the low places to collect. Inside the muffler typically gets a bit which you dump out by pointing the model up. And the bottom of the crank case is another popular spot which can leak out the front bearing if they're not sealed. If they are sealed and they leak you may need a new bearing. As long as the engine performs as it should and it's not gushing oil from these places then there's no real reason to worry. Some engines simply leak in more places than others. At least you know they're getting well lubricated.
Then again you never said how much oil you're finding in these places. Nor the make and model of the engines, how they're mounted (upright, inverted, etc.) and fuel being used.
speedracerntrixie 04-25-2021 06:37 AM
With the limited information it could be as simple as the one engine that is dripping has the fuel tank installed too high. This would allow fuel to siphon into the engine. Other options would be the engine is not adjusted correctly ( too rich ) or the other one is adjusted too lean. More specific information would be helpful.
kumkumking 04-25-2021 09:47 AM
hi thanks for the reply
the engines are ABC-sc61 two stroke and mounted upside down because of the cowls on a seagull mosquito, the fuel is liquid gold
20% castor and synth with 5% nitro,its just one engine i was worried about as no oil was in the muffler,the fuel tanks are set fine as
per instructions-kind regards the kum
speedracerntrixie 04-25-2021 11:53 AM
Are the engines new? It could be that one is breaking in a bit better then the other one due to manufacturing tolerances. Are you tuning them by ear or using a tachometer? I did look up some pictures, it appears that if the tanks are mounted at the very bottom of the engine nacelles you would be fine. Unfortunately you can't always count on the ARF manufacturers to get everything right.
jaka54 05-05-2021 12:29 AM
Originally Posted by kumkumking (Post 12673533)
hi
Hi!
Leaking fuel/oil through the front bearing is normal for all glow engines and is nothing to worry about.
