need help in starting my engine :(
hi guys i have an OS25FX and i want to start it with hand.
i cant seem to be able to do that i winded it for over 0 min and still could not egt it to start i charged the glow plug over night and not sure wat more to do. coud u give me tips on how to start it. |
BTW I poted this for you on another post. Why the cross posting?
RFrost; The sharp end goes down on the right facing the motor, On a 25 to start without a Electric Start you can turn the High end needle to approx 2 full turns out from closed. To roughly adjust the low end take a piece of fuel tubing attach it to the carb. Now take a small jewlers screwdriver and close the low end needle. While blowing in the fuel tubing attached to the carb start adjusting the low end needle out till you just hear the air coming through the carb. Leave it there for now. Now re-attach everything to your carb i.e. Tank fuel tubing and pressure line to the Muffler. Open your throttle full, put the Glow starter on and hand turn the engine slowly till you feel a slight kick-back. You may have to put your finger over the Carb to Choke it, to get the fuel to the carb. Now with a chicken stick (can be a screwdriver or a stick with a piece of rubber on it) Flip the prop counterclockwise. Btw to make thing easier set the so it's at the top of compression at approx 1-2 O'clock. This will make it easier to start. As well keeping you away from the blade on your follow through while starting. |
great i managed to get the engine started but i have a slight problem i dont get wat u mean by idle setting y do i need to set it?
onece i closed the needle valve the power is amazing ! with lowest throttle setting! then when i opened the valve the engine started to shake like mad so i closed it back again! wat do i have to achive really? |
oh ya one more thing i have fuel kinda spraying out of the muffler and some times form the carborator! is that normal?
Rag, do yourself a favor go to a local club and get some help with that engine before you damage it. There are several things you need to learn about setting up an engine for proper performance, to much to list here
ok i will do that then :)
my hands were very itchy to start the engine and hear it roar :D |
| All times are GMT -8. The time now is 09:38 PM. |
