RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   taildragger builders (https://www.rcuniverse.com/forum/beginners-85/1375353-taildragger-builders.html)
Pocho 12-24-2003 12:47 PM
I've built and covered a gp piper cub. When it was time to install the rudder I realized in horror that the elevator prevents the rudder from fitting flush with the vertical fin! I have at least 1/2 inch gap on bottom of rudder. That small piece of horizontal wire that connects both halves of the elevator prevents the rudder form fitting properly, how do you guys handle this?
gus 12-24-2003 01:14 PM
RE: taildragger builders
I just browsed through the manual (for the 40 size kit). It is not clear on what to do.
My gut response is that you should cut a slot in the rudder so that the metal rod can move freely, and the rudder slots over (bridges) the rod. The closes I can come to an answer is the picture on page 31 of the manual above step 12. See how there is a hollow in the rudder to lety the rod fit?
gus
CafeenMan 12-24-2003 01:18 PM
you have to notch the rudder for the elevator joiner if that's what you're talking about. DO NOT glue your rudder on with a 1/2" gap. Fix it however you have to.
Pocho 12-24-2003 01:25 PM
Gus, cafeenman
That is the answer I was hoping for. THANK YOU!
dr_wogz 12-24-2003 01:27 PM
Usually we cut a notch in the rudder, to clear the elevator link / bar. In worst case senatrios, we will beef up the wood behind the 'notch' .
MinnFlyer 12-24-2003 01:35 PM
1 Attachment(s)
ditto
CafeenMan 12-24-2003 01:45 PM
Mike - do you have a drawing showing what to do if the joiner is behind the hinge line? That half-moon sort of cut-out that's needed. Sounds like that's what he needs.
gus 12-24-2003 02:01 PM
Seriously MinnFlyer ... your drawins are sooooo inaccurate .... that is NOT "Cub Yellow"!
gus
MinnFlyer 12-24-2003 02:23 PM
1 Attachment(s)
Picky, picky, picky! :D
Cut as needed.
PS, Note color change
CafeenMan 12-24-2003 02:34 PM
Yep... the second one is easiest. :)
Want to do some art for my website? I only need about 200 drawings. The pay is great if you think "thanks" is good pay. :D
gus 12-24-2003 02:36 PM
If I cold be reallly picky... the first picture is not a solution because the elevators already have the torque rod in them, and trying to thread an elevator through that intsy bitsy hole .... well, it is like santa down the chimney, just won;t happen ;-)
gus
