RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Sullivan High Torque Starter Dimensions (https://www.rcuniverse.com/forum/beginners-85/1393099-sullivan-high-torque-starter-dimensions.html)
RH1N0 01-01-2004 03:15 AM
Hi All and Happy New Year!
I am building myself a flight box and plan to include a compartment for a Sullivan high torque starter. Problem is I haven't bought the starter yet so I don't know how big to make the compartment. Spent the last hour searching the web for the dimensions but just can't find them[&o] Can someone please measure their starter and tell me the dimensions.
Rhino
southern_touch9 01-01-2004 11:40 AM
RE: Sullivan High Torque Starter Dimensions
Which sullivan starter? ARe you talking about the Dynatron? Mine is set up on pullys and 24Volts for cranking the REAL BIG engines so the dimensions would be off.
RH1N0 01-01-2004 04:27 PM
I'm thinking of using the "Deluxe High-Torque Starter" (see http://www.sullivanproducts.com/StartersContent.htm). I will be using the starter with the basic aluminium drive cone - no pulleys etc. The Sullivan web page lists the motors as having a 2.5" diameter body so I assume the width is 2.5" but it doesn't list the height (of the big plastic end cap) or the length (end cap to end cap and also total length including starter cone). I am also interested in the same dimensions for the Dynatron.
Can anyone spare a minute to measure theirs?
phread59 01-01-2004 05:15 PM
Hi RH1NO:
I can help you there. I have an older Sullivan Hi-Torqe starter. The Handguard/front plate is 3" across and 3 3/4 " high and 7 1/2" in length. That is with a Sullivan replacement starter cup in it. I got a white one which is grippyer than the stock one. It is also set up for prop nuts which I use mostly. I hope this helps you out.
Mark Shuman
PS: the motor housing is 2 1/2" in diameter.
RH1N0 01-01-2004 05:40 PM
Thanks a milion Mark! That's exactly the info I was after.
phread59 01-04-2004 04:54 PM
You are quite welcome. Glad to be of service.
Mark Shuman
