Fuel Dot Question ????
Hi,
Just a question what is a fuel dot system ??? ive never heard of that anywhere over here in the uk, most of my planes have cowls, and i use the quick filler valuves. I know these are known for thier problems but most of my planes its impossible to access the engine inside the cowl. Any suggestions as to a different method or filling and de-fueling the plane in this setup ? i normally use fuel tanks with 3 lines if that makes a difference..... Thx for any help. as i still have a few more kits to build and would like to try a diff method. |
RE: Fuel Dot Question ????
A fuel dot is just an aluminum plug that plugs the fill line when you have fueled the plane.
You can go to www.jtecrc.com and click on accessaries. Under fueler you will see a typical fuel dot. Tower Hobbies carries there line as well. [&:]
Yes it's a plug, but it's also a fitting that mounts to the cowl with a nut, the "plug" fits into the fitting.
Dennis- |
Ok i use this method, just never heard it called a fuel dot before over here :)
Thx for your eplays. Can i ask which line is the best to have it on ? like i said i normally use tanks with 3 lines........................ Thx |
On the fill line is where it is used.
2 or 3 line systems are the same. ORIGINAL: DragonHeart Ok i use this method, just never heard it called a fuel dot before over here :) Thx for your eplays. Can i ask which line is the best to have it on ? like i said i normally use tanks with 3 lines........................ Thx |
Original: Geistware On the fill line is where it is used. 2 or 3 line systems are the same. |
I use fuel dots on a two line system and never flood the engine, I use a T and a check valve and the fuel goes to the tank not the carb.
Original: perdo I use fuel dots on a two line system and never flood the engine, I use a T and a check valve and the fuel goes to the tank not the carb. |
Yeah, check valve doesn't make sense, but I haven't had too much trouble by simply closing the carb before fueling. But I think a lot of it depends on the relationship of Fuel Dot placement compared to the level of the carb and the tank. (oh, and it helps if you can remove the pressure line from the muffler.)
Dennis- |
| All times are GMT -8. The time now is 11:34 AM. |
