RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Modifying battery packs (https://www.rcuniverse.com/forum/beginners-85/1438299-modifying-battery-packs.html)
iroks 01-17-2004 01:17 AM
I was recently given a Pico Cub for an xmas present. Since it's my first R/C I have taken my time putting it together wanting it to be right. Also, everything was sent to us from a model shop hundreds of miles away so popping back into the store isn't an option and where I am located is miles away from any R/C model shop.
Anyway I was told that I could modify the battery pack sent to me with this plane. Because they didn't send the exact battery pack for the plane as intended by Multiplex. I was sent a pack which was based of 7 batteries next to each other in one long row.
Obviously this won't fit into the plane so the model shop I got it from said I could take the casing off and change the layout of the batteries to fit into the plane. There are flat metal strips that connect each battery and I had to remove one of them to do this. Putting it back on I think I may have done it slightly wrong.
I used a bit of superglue to hold the metal strip onto each battery and I only realised once it was done that I should probably not have done this. Does the superglue act as a barrier between the batteries, or will the current still flow? There are sections of this strip that do touch the battery but not as much as originally.
Should I remove the strip again and just place the metal strip on and put tape over the batteries to hold it all together?
mstroh3961 01-17-2004 01:22 AM
RE: Modifying battery packs
YOU MUST SOLDER THE CONECTOR BARS ON! Glue will not work!
Crayon 01-17-2004 01:55 AM
Just heat the joints with a soldering iron, and apply solder to your super glued tabs. The heat and rosin will burn off the super glue in short order.
Make sure you use 60/40 rosin core electical solder, not plumbers lead with acid flux
iroks 01-17-2004 08:57 PM
hey thanks for the advice - really appreciated
whstlngdeath 01-18-2004 02:15 AM
Also, make very sure that the cells are connected in series, positive (+) end of one cell to the negative (-) end of the next.
Jesse
