RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   hello (https://www.rcuniverse.com/forum/beginners-85/1439710-hello.html)
nitrobasher 01-17-2004 05:07 PM
hello
hey guys im new to the board and to airplanes... i bought one about 3 years ago and i just got out of it + it fell off a shelf and got pretty wrecked. iv been into rc cars/trucks pretty much from then on. But iv been looking to restore my airplane, its a
tigertrainer mk2... i was tryin to charge the battery today but i couldnt figure out wich wire to plug in... any help would be appreaciated thanx again:)
JohnW 01-17-2004 05:54 PM
RE: hello
Welcome! Your first priority is to locate a local flying club and seek out experienced pilots locally. You will need a safe and insured place to fly your plane, i.e., read club here. You will probably also need some help learning how to fly. This is especially true since you indicate your plane may have some damage. While you can get a lot of help from this forum, it is often hard to determine damage from photos. It would be much better if an experienced pilot could actually look at your plane and help you with any required repairs.
As for the battery, I assume you are talking about the RX battery. Most often these are plugged into a switch harness, and you charge thru a wire attached to the switch. The swithc will often have three wire bundles. One for the battery, one for charging, and one that is operated by the switch that goes to the RX. If in doubt, you can always remove the battery and charge it directly. However, most will suggest replacing NiCd batteries after 3 years. You may wish to find someone locally with a battery cycler that can test your battery since it has sat for so long.
Cheers.
nitrobasher 01-17-2004 06:04 PM
RE: hello
thats the problem... i hav no idea where the battery is located... i cant see it all i see is the reciever wich all the wires plug into, do u guys no the most popular place a battery is found.. thanx again
causeitflies 01-18-2004 02:23 AM
RE: hello
Follow the wires from the switch. One lead goes to the RX, one to the battery, and one to charge.
nitrobasher 01-18-2004 06:49 PM
RE: hello
i found the battery got it hooked up and charged... i went to the lhs and got some epoxy and new clips and set the whole thing up... im waiting for a nice day to wonder up to the local track to see if i can make some new friends lol thanx again[sm=lol.gif]
