RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Y harness help (https://www.rcuniverse.com/forum/beginners-85/1486073-y-harness-help.html)
jetfly 01-31-2004 09:21 PM
Y harness help
Hi, I'm planning to buy a y harness for my receiver. I want to know if the y harness has to be the same maker, of my receiver, for it to work. Example: can I use any kind of y harness for the receiver? Thanks, I appreciate you guys answering me!!:D
DMcQuinn 01-31-2004 09:34 PM
RE: Y harness help
Any "Y" harness will work as long as the plugs on the end are compatible. Generally all the major brands are interchangeable (futaba, JR, airtronics, hitec). The servo plugs are nearly identical, except the Futaba has some extra plastic that you may need to trim off with a razor blade. The main thing is that all servos and receivers expect 3 wires to be in a certain order and all the manufacturers are now the same.
tailskid 02-01-2004 01:08 PM
RE: Y harness help
I 'favor' the same mfg. only because they stay connected better than some of the second-market mfgs.
Jerry
Geistware 02-01-2004 03:19 PM
RE: Y harness help
Many companies make very good harnesses. It does not have to be from the radio MFG. I would say that it does need to be HD wire and gold contacts.
ORIGINAL: jetfly
