?? for Stick40 Plus kit builders
The booms that came with my kit are 40 inches long, but the drawing shows a boom 42 inches??? What's up with that? Am I just looking at the drawing wrong? My "manual" is from a vintage kit and isn't any help on this question. I will have an updated kit's manual soon, and it should be more helpful with these types of questions but I'm impatient to get started...
auto5man |
RE: ?? for Stick40 Plus kit builders
I do not have this kit. My guess is that they will work. 2" on the length should not make much difference. If you feel that you need to just run to the LHS and get some new wood. I would double check the plans and if the sticks are short I would use them. That is my own personal opinion.
Mark Shuman |
I just measured the ones on my completed fuselage and they are 40".
Mine are 40" also.
Go for it. Bill |
Lightfoot and Redwing,
When you look at the plane from the nose end then, the piece of wood called the "motor mount" and the boom end and the plywood side of the fuse....are these three pieces flush? auto5man |
1 Attachment(s)
Yes.
They are flush. It is 40" from front to back. Here are some pics. Bill |
1 Attachment(s)
Does your plan look like this?
Redwing,
Oh MAN, you guys are lifesavers! No, my plan doesn't look like that...it doesn't have that overhead view(which makes it very clear) it only has a side view. I'm at work right now, but when I get home I'll take a picture of my plan and post it if I can figure out how to post the pic.. (havn't done that before) auto5man P.S I don't get off work until 11pm. |
1 Attachment(s)
Ok Redwing...I'm still trying to figure out how to get these pics to show up on my post...
1 Attachment(s)
It worked...the next pic shows my instruction "manual"...only two pages...
in the previous post, the drawing shows a side view and that is the only view of the fuse drawn...I don't have the top view like your plan has. |
1 Attachment(s)
....And the third pic is the 2nd page (and LAST page!) of my instruction manual.
auto5man |
Those plans don't look anything like mine.[:o]
You might want to wait for the new plans to arrive. Bill |
will do....thanks for the help!
auto5man |
| All times are GMT -8. The time now is 12:00 AM. |
