RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   How important is balancing plastic spinner backplate? (https://www.rcuniverse.com/forum/beginners-85/1635129-how-important-balancing-plastic-spinner-backplate.html)
CrashBurn69 03-17-2004 08:08 PM
I got my prop balanced and now I am working on the backplate. It is the stock one that come with the Avistar. I am using a Top Flite balancer. I have about 10 holes drilled in one side and its not even showing signs of lightening. Am I doing something wrong?
wings 03-17-2004 10:29 PM
RE: How important is balancing plastic spinner backplate?
I am rather new to RCU myself. I started with a trainer last fall, I have a 4 star now. I have never balanced a prop. I believe balance becomes and issue with larger engines that spin faster and heaver props. If its a trainer, I wouldn't worry about it.
DBCherry 03-17-2004 10:31 PM
I think you have plenty of holes in that back plate by now, I'd leave it alone. ;)
Seriously, I've never balanced a spinner, and never had a problem with one either.
Dennis-
Jim C. 03-18-2004 12:28 AM
nope, never had a prob either, 10 holes, spinning at 14,000 rpm, just becareful. stay out of the plane of rotation
Geistware 03-18-2004 06:42 AM
The drag on your balancer is more than the weight of the spinner.
With 10 holes in a 2 inch spinner, I would be careful of it coming apart.
aimmaintenance 03-18-2004 07:11 AM
Ya I'm thinkin buy a new spinner and just put her on.
CrashBurn69 03-18-2004 08:43 AM
I do have a spare I guess I could throw that on. Thanks
Dsegal 03-18-2004 09:16 AM
> larger engines that spin faster and heaver props. <
It seems to me that it is the smaller engines that have higher rpms.
wings 03-18-2004 04:49 PM
Proabably right. Point was it is not needed on a normal trainer such as the Avistar.
ifixairplanes 03-18-2004 05:15 PM
no it's not needed, all that will happen is your electronics will get shaken to death....seriously, even a crappy trainer, you get better performance with a balanced prop. I ALWAYS balance my props. Good article on balancing them in the newest Model Airplane News. A spinner on the other hand, i have not balanced one. I think i will do one tonight and see how it comes out.
sean
Mike Ledbetter 03-18-2004 05:26 PM
I had terrible vibration problems from a spinner after I enlarged the holes to accomodate a larger prop.
Spinners do need to be balanced, but a small shaving of material should do it. I'd start over if I was you.
regards.
CrashBurn69 03-18-2004 07:58 PM
I picked up a dubro 2" spinner but now I am having trouble getting it on my 11x4 prop. I can't get it to snap shut. But it ballaced pretty good with no mods.
wings 03-18-2004 08:14 PM
Did you try moving the prop one way or the other before tightening the nut. Sometimes putting it all the way against the stop is not the right spot.
Crash Master 03-18-2004 09:01 PM
On the Avistar with an OS 46 forget the spinner and what possessed you to want to put an 11x4 prop on it? I run a GMS 47 on a strickly 3D bird with an 11x4 prop cause it needs the thrust. Are you planning on trying to hover the Avistar?
Good luck,
CrashBurn69 03-18-2004 09:15 PM
CM YEP thats the plan. I had to switch to a 2 1/4" prop to use that pitch. I pulled the spinner out of my Funtanna bag, works like a charm. I like the dubro a lot better. I might get me another yellow one in that size, for giving a more directional apearance, plus the yellow looks good. A dubro spinner would just not acomidate that pitch blade. I stuck a 10x7 and it snapped right up. Now I just need to get the darn plane balanced. Besides, with an 11x4 I hope it should cruise very slowly.
steener 03-18-2004 09:20 PM
the 11x4 is a good prop for the avistar(from experience). it doesnt fly overly fast and lands slow. i started with a 10x6 but the 11x4 works much better. the 10x6 was fast and it wouldnt climb neer as well as the 11x4. try both and youll see. they both work though.
CrashBurn69 03-18-2004 09:23 PM
I have a 10x7 also, but I think I am going to start with the 11 and work my way down. I have a date semi set with my local field to get checked off, and soime instruction, in 2.5 weeks. Looking forward to get in the air again.
a65l 03-18-2004 10:13 PM
I trashed spinner on mine, got me a du-bro spinner nut. Looks like a mini spinner, works like a prop nut, balanced right out of the package and it works with an electric starter. I tried balancing my spinner as well, but while it balanced out on the prop balancer, I noticed a little bit of off-center rotation, so it might not be dynamically blanced... either way, the prop nut is a LOT easier to get on and off.
Andy
CrashBurn69 03-19-2004 08:28 AM
I will have to check that out. Thanks
