Push Rods
Hello there.
As a total beginner to the hobby, I am just putting my 1st ARTF together. The Push Rod on the Elevators is slightly too long, but overly long to be just trimmed out. The question is, what is the best way to put a new bend in the push rod? Is there a set way to do this with a tool or something, or just to go ahead and bend it? |
Push Rods
Need more info in order to help you. what type of push rod? What type of ends?
Z Bender
A tool is best used to install Z bends in the wire
Push Rods
1 Attachment(s)
Originally posted by Rodney Need more info in order to help you. what type of push rod? What type of ends? |
Push Rods
1 Attachment(s)
And another
Re: Z Bender
Originally posted by michael lewis A tool is best used to install Z bends in the wire |
Push Rods
If its just a bit too long, just make the bends there right before the horn a bit sharper to take up the extra length. That is an old method of adjustment on small planes.
Push Rods
Originally posted by Tom Nied If its just a bit too long, just make the bends there right before the horn a bit sharper to take up the extra length. That is an old method of adjustment on small planes. |
Push Rods
Another easy way to control the slack in your pushrods is to use EZ Connectors. They are the best way in my opinion for adjusting push rods. you can use the Z Bend method that you are using now on the tail, and attach these :
http://www2.towerhobbies.com/cgi-bin...1&I=LXD925&P=0 to your servo arm. The pushrod goes through the connector, and the screw on top of the EZ Connector tightens down to the length needed. |
Push Rods
What size (engine size) plane is that anyway? If it's a 25 or larger, I'd get rid of those flimsey pushrods anyway.
Push Rods
Originally posted by MinnFlyer What size (engine size) plane is that anyway? If it's a 25 or larger, I'd get rid of those flimsey pushrods anyway. |
Push Rods
Good luck man! I hope it gives you many hours of......"crash repair" lol, I mean many hours of fun and enjoyment!
Push Rods
1 Attachment(s)
Originally posted by tmproff Good luck man! I hope it gives you many hours of......"crash repair" lol, I mean many hours of fun and enjoyment! Wing: |
Push Rods
1 Attachment(s)
Crack in tail
Push Rods
The small dent in the wing will not be a problem unless it's caused a stress crack in the foam that your pic doesn't show. Flex it gently or simulate a flight load by holding it up by the wing tips to ensure a crack doesn't open near that dent.
The tail crack will be another issue. Flight loads will cause it to move and it will break off pretty quick. Clear packing tape might hold it for a quick repair. 5min epoxy or foam safe CA will make a good permanent fix. I might be tempted to take the fin-rudder off so I could get the stab nice and straight. Depends if you can get the fin-rudder off without dammage. Epoxy will add a significant amount of weight so check the CG again after the repair. |
| All times are GMT -8. The time now is 02:37 PM. |
