RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   thunder tiger TIGER TRAINER is LOUSY (https://www.rcuniverse.com/forum/beginners-85/1650642-thunder-tiger-tiger-trainer-lousy.html)
SuperStick 03-22-2004 11:00 PM
For all you new guys do yourself a favor and stay away fron the thunder tiger tiger trainer, I put one togther for one of the guys at our field and to say the least it stinks. THe top of theplane is plastic and the bottom is balsa and its held togther with a sticker LOL LOL. Its nearly impossible to get the tail feathers lined up and unless you have been around models awhile there are so many bad design features you wont know how to correct them. While im not the best builder around i do know a bad model when I see one and this has to be the worst model I have ever been around. Do yourself a favor and stay away from this one.
Geistware 03-23-2004 06:52 AM
RE: thunder tiger TIGER TRAINER is LOUSY
While I have not trained anyone on this plane. I have seen many and you are the first I have heard with a problem. Maybe you received one that was not up to your expectations.
Backwing 03-23-2004 11:03 AM
That was my first plane. I thought it was fine. Went together well, and didn't have any bad flying tendancies. The top never seperated from the bottom:)
Yub, yub, cmdr! 03-23-2004 02:49 PM
Also interesting.
Thunder Tiger's car stuff is really good (according to RCUniverse people).
I plan getting a few Thunder tiger (called Lei Hu in China) engines this summer.
I think you got a fluke. Everybody I know that has a Tiger 2 likes it, but I got one that had TONS of problems. Maybe the same happened in your case.
SuperStick 03-23-2004 11:47 PM
I may have gotten a bad one, This is the first thunder tiger aircraft I have assembled and i am comparing it to the hobbico avistar, airvista, and the other hobbico trainers. Here is what I found.
There was no opening pre cut for the elevator pushrod to exit.
THe supplied dowel rods for the rudder and elevator were not long enough to make it to the control horns
THe opening for the servos in the servotray was way to small
THe formers would break at the slightest touch.
THere were no cut outs in the formers for the nose wheel control rod to fti so it would clear the tank.
THe covering is sticky back.
It is my opinion that for a first time modeler there are just too many problems compared to the ones I have built. Not that I am hobbico fanatic but they dont have the isuuses that the tiger trainerdoes
Skribnod 03-24-2004 01:47 AM
My buddy bought a 60 size thunder tiger trainer and flew the wheels off of it. I think he had over 100 flights easilly and no problems at all. Maybe you just got a bad one?
Woody 51 03-24-2004 05:29 AM
Sorry to disagree with you S.S.
Sure, they can be a bit of a pain to put together when compared to some of the modern day offerings. But they fly great.
Medium CA and accelerator fixes the balsa to plastic join problem.
My daughter put one together and learnt to fly with it about 5 years ago. She still has it, though she hasn't flown it for a while, having graduated to more advanced models.
As for the other problems you experienced. Sounds like a typical ARF to me. I haven't come across one yet, that I haven't had to change or strengthen some part. Even W.M stuff.
fiveoboy01 03-24-2004 12:47 PM
I agree with woody. My Tiger Trainer .25 went together well and it flies wonderfully. I have 12 flights on it so far. Yep, it has some typical quarks but I think nearly any ARF has these.
-Bill
glueboy 03-25-2004 07:07 PM
PICA Gluit also works good for plastic to wood joints.
Groucho fan 03-25-2004 10:49 PM
I agree with SS, I was tempted to buy one when I first started, but bought a Superstar
instead. My friends tried to repair them said they were not easily repairable, too much
plastic, not enough wood, tail fin, fuselage one piece. Superstar much better made.
ShaneUSMC 03-25-2004 11:08 PM
Yep. Sounds like a TT Trainer to me.[8D] I've had mine for 5 years. I think I'll finally retire it. I keep kicking the rudder off (while stepping over it for motor run up).[:@] Everything you describe above was the same as on mine with the exception of the servo openings and the formers breaking. They repair quite easily though; if you have the all balsa ones they used to make, not sure about the newer ones.[&:] On a lighter note, if you want it to perform alot better take some of the dihedral out of it and remove the wing tip covers and put a balsa cap on it. Flies soooo much better.:D:D
Lightfoot 03-26-2004 08:40 AM
I bought a Thunder Tiger Trainer 40 about 10 years ago. Maybe my years of building had something to with it but I had no problems assembling the model. I went through it looking for problems before I started the assembly and had no problems. I had one crash with it due to onboard battery failure and the repairs were not at all difficult. My only complaint was the sticky covering. I removed it while doing the repairs and recovered it with Sig plastic covering and it is still flying.
