RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Dumb question... (https://www.rcuniverse.com/forum/beginners-85/1677259-dumb-question.html)
Gizzmo0411 03-31-2004 01:25 PM
Dumb question...
I've been looking at buying a Superfly-E kit combo from www.superflyrc.com but I don't know what type of charger to get! AC or DC, it's asking to specify...but I'm just confused...I know there's an important difference but for the life of me I can't remember what. Any help?
FLYBOY 03-31-2004 01:30 PM
RE: Dumb question...
AC works from the electrical in your house, DC works from the battery or cig lighter in your car.
Gizzmo0411 03-31-2004 01:57 PM
To further my inquiry...In the instructions it says that I need shoo goo, CA, CA kicker, and 5 min epoxy...I'm going to assume these are all adhesives...do I need all of them to build this plane???
FLYBOY 03-31-2004 02:13 PM
CA is instant glue, the kicker makes it go off faster, don't use CA around the foam. 5 min epoxy is just that, and will be used proably the most, and shoe goo is a glue they use probably for gluing the foam pieces together. The CA will be used on balsa pieces and epoxy for gluing in the servo mounts and stuff. You can probably get by without the CA, but if you use just epoxy it will be heavier and you don't want to make that plane too heavy. It won't fly well.
Commander_Drake 03-31-2004 02:18 PM
Yes. You will need all three types of adhesives for different parts of the asembly. You don't really need the CA Kicker you can just hold or clamp things in place for a few minutes instead. The Shoe Goo is probably for attaching servos or somthing else inside a foam cavity. I think I have used RC56 for this.
The epoxy is for a strong joint when joining major parts together like the wings to the fuse or the wing halves to each other. If you have 30 minute epoxy you can use that, you just have to clamp the parts together longer.
a65l 03-31-2004 03:04 PM
There is specific CA for foam, very effective if I do say so myself.
Andy
Spadinator 03-31-2004 03:57 PM
Be careful...I used shoo-goo on foam and it melted it!!!!! The foam was the blue insulation type.
DRDHalko 03-31-2004 04:51 PM
Gizzmo0411
Answers from SuperFly RC:
Both AC and DC chargers do the same thing, one simply plugs into the wall, the other into the cigarette adapter in your car.
You only really need Shoo Goo to put the plane toghether. Yes, Shoo Goo. It WILL NOT MELT the EPP foam that the plane is made of!
DON'T use epoxy to put major parts toghether, it is too brittle and will crack over time.
You do not have to use Foam Safe CA on the EPP foam, regular CA will work just fine and WON'T MELT IT.
I need to update the materials required list but you only really need Shoo Goo....
You can always call me at the number listed on my site.
David
www.SuperFlyRC.com
All EPP Delta Wings
Jim Finn 04-01-2004 05:43 PM
I suggest you get the DC type charger. You can then charge battery packs at the field from your car battery and at home.........when at home where is your car?
Gizzmo0411 04-10-2004 02:26 AM
Mmm...problem with that...I don't have a car! lol
I went with the AC...I'll just get a bunch of battery packs later so I can do all the charging at home.
Montague 04-12-2004 11:02 AM
It's cheaper to just pick up a 12v field battery, like a gel cell sold for hobby use, or a lawn tractor or motorcycle battery. That will give you a reasonable weight power source for a DC charger in the field.
