RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Slow Stick (https://www.rcuniverse.com/forum/beginners-85/1721958-slow-stick.html)
SimonBryant 04-14-2004 06:53 AM
Slow Stick
Any recommendations to secure the tail more?
NeoLogic 04-14-2004 09:45 AM
RE: Slow Stick
I used a good sized bead of white foam compatible CA along the fuselage and tail feathers.
http://www.amazon.com/exec/obidos/tg...A2LM8ZC59IT9RX
flying_frog 04-14-2004 10:06 AM
RE: Slow Stick
I did the same with the CA...works great.
glowplug 04-14-2004 10:32 AM
RE: Slow Stick
I roughed up the aluminum a bit with sandpaper and used a thin line of expoxy.....it's survived a lot of flights.....including 3 mid-airs (indoor slow-stick combat) :D
SimonBryant 04-14-2004 11:07 AM
RE: Slow Stick
Thanks for your input guys.
The other thing i thought of doing was applying a thin piece of bolsa wood between the tail and fin either side, i would mount this just by 5 minute epoxy resign, this could help strengthen the fin? Anyone done this before?
By the way CA - is that Super Glue?, i don't understand some of the US terminology, i'm getting their slowly.
Thanks again
Simon
Nebbie 04-14-2004 11:19 AM
RE: Slow Stick
Yes, CA is Super Glue. Comes in thin, medium and thick. I get mine at the hobby shop.
flying_frog 04-14-2004 11:40 AM
RE: Slow Stick
CA is a kind of super glue. But it is not the same as super glue sold at the super market. CA stands for Cyanoacrylate. If you want to use it on your SS, make sure you get a bottle that can be used on foam. Regular CA will eat and melt the foam.
Another suggestion is if you intend to use CA, get a bottle of debonder too. This will unstick your fingers when you glue them together...and you will.
Todd_J 07-19-2005 02:22 PM
RE: Slow Stick
I braced the rudder fin with two stryene plastic tubes about 1/4" in diamter. One end of each tube I CA's to the top of each side ofthe rudder fin and the other end of each tube was CA'd to the far ends of the elevator fin. These two dihedral braces have saved my tail in more than one crash :)
