Evolution 61 NT
I like to know what propeller to use with this engine, The Evolution 61 NT. The manual does not says any thing about it.
RE: Evolution 61 NT
Something around the 12x6 to 12x8 size ????
RE: Evolution 61 NT
Only Two Propellers ? I install this engine to Extra 300 S 60 of Seagull Models.
RE: Evolution 61 NT
That sounds about right
RE: Evolution 61 NT
I experimented with different props and found the APC 12x6 seemed to work best for me on that engine. Just the right amount of torque without sacrificing a lot of speed. The Evo .61 is a good engine. I ended up selling the plane (Ultrastick 60) and engine to my brother. If it was a dud I wouldn't have sold it to my brother!;)
RE: Evolution 61 NT
I planing to use 12x6 scimitar propeller, is that ok ?
RE: Evolution 61 NT
The scimitar will probably work just fine.
RE: Evolution 61 NT
:) Thank you I wil try this weekend.
RE: Evolution 61 NT
Straight from the Master Airscrew technical bulletin on props:
2-Stroke Engines .049 - .051 = 5.5x4, 5.5x4.5, 6x3, 6x3.5, 6x4 .09 - .10 = 7x3, 7x4, 7x5, 7x6 .15 = 7x6, 8x3, 8x4, 8x5, 8x6, 8x7 .20 - .25 = 8x6, 8x7, 9x4, 9x5 .29 - .35 = 9x6, 9x7, 9x8, 9.5x6, 10x4, 10x5, 10x6 .40 = 9.5x6, 10x4, 10x5, 10x6, 10x7, 10x8, 10x9 .45 - .50 = 10x7, 10x8, 11x4, 11x5, 11x6, 11x7, 11x7.5 .60 = 11x5, 11x6, 11x7, 11x7.5, 11x8, 11x9, 11x10 .71 - .80 = 12x6, 12x8, 13x6, 13x8, 13x10, 14x8 .90 = 13x6, 13x8, 13x10, 14x6, 14x8 As you can see, there is a fair variety to select from. Don't be afraid to experiment within reason. You will be able to tell fairly quickly what works for you . Good luck. |
RE: Evolution 61 NT
According to Power Point's top flight chart you can use the following,
11 X 6 , 11 X 7 , 11 X 8 , 11 X 10 , 12 X 6 , 12 X 8 ,been using the 12 X 6 with success. |
RE: Evolution 61 NT
Thank you BINGO FIELD and 5_SPOT those charts are very help full..
RE: Evolution 61 NT
The ads for the EVO engine state that they get 12000 rpm with an APC 12-6 prop. This sounds like a pretty strong engine if thats the case so thats what I put on the front. The first days flying I only got around 11,300 rpm which was dissapointing. The next time I took it out it started to pick up revs. After a few flights I was getting 11,600 rpm. By the end of the day I never checked the rpm but the plane was burning holes in the sky and I am really begining to like this engine! Based on this I would throw on an APC 12-6 and go have fun![:D
| All times are GMT -8. The time now is 12:59 AM. |
