RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Engine Cleaner (https://www.rcuniverse.com/forum/beginners-85/2000003-engine-cleaner.html)
jriebold 07-17-2004 08:27 PM
Engine Cleaner
Any suggention on how to get the a glow engine and muffler clean from residual oil and other burned on grime.
Thnaks
redbirdy 07-17-2004 08:44 PM
RE: Engine Cleaner
I used the anti-freeze method. I had heard about it but never gave it too much thought until a friend of mine tried it. I put it in a pot and filled it with some cheap anti freeze and heated it until it just started to steam. I let it sit for 4 hours at this temperature. It worked really well.
bigchap 07-18-2004 03:35 AM
RE: Engine Cleaner
i second that,i bought some of the gungiest engines you ever saw at an auction,they were in the pot for about 6 hours and came out like new,the wife went mad about the pan though!
DBCherry 07-18-2004 06:41 AM
RE: Engine Cleaner
The crockpot and antifreeze method is about the easiest method I've ever seen. Just be sure to never use the crockpot for food again! You'll poison yourselves.
Dennis-
jriebold 07-18-2004 12:26 PM
RE: Engine Cleaner
Thank you for the anti freeze idea. How does this method affect o-rings in the carb. and needle valve? Does anything need to be removed from the engine / muffler other than fuel lines.
Jerry
