RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   balance lateral (https://www.rcuniverse.com/forum/beginners-85/2022145-balance-lateral.html)
tree 07-25-2004 01:57 PM
balance lateral
How do you guys balance your planes laterally
bowencutie 07-25-2004 02:07 PM
RE: balance lateral
You and another person is needed- place one finger under each wing right where the spar comes to the tip. Shows if plane is nose heavy or tail heavy
Mary
tree 07-25-2004 02:35 PM
RE: balance lateral
laterally, means wing tip to wing tip,not cg. Thanks anyway
carrellh 07-25-2004 03:25 PM
RE: balance lateral
Its easiest with 2 people but you could do it alone. At the back, put a mark on the bottom of the fuselage in the center. At the front, loop a string around the prop shaft. Lift by the string and at the rear mark.
bowencutie 07-25-2004 04:03 PM
RE: balance lateral
ORIGINAL: tree
sorry- as my instructor says -- your other left silly
Connery 07-25-2004 07:02 PM
RE: balance lateral
The way I do it is to set the spinner on a 1 gallon paint can and then lift the tail with one finger from the under side of the fuse. I lift it just slightly to where the plane is level with the height from the nose sitting on the paint can.
MinnFlyer 07-26-2004 10:04 AM
RE: balance lateral
I do the paint can method too. Get a can, or a box, or what ever will just fit under the spinner, and lift the tail. repeat this 3 or 4 times. If the plane goes to one side every time, add some weight to the opposite wingtip.
Here's a little more info, scroll down to the part about lateral balancing:
http://www.rcuniverse.com/magazine/a...?article_id=84
