RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Beginner Flight box advice. (https://www.rcuniverse.com/forum/beginners-85/2041899-beginner-flight-box-advice.html)
mrjones30 07-31-2004 07:45 PM
1 Attachment(s)
Hello and thank you in advance for all of your help.
I have a beginner question:
Before relocating my friend gave me his collection of flight equipment, (I think his wife had something to do with it....laughs) and I have a flight box made by Hobbico. I tried to turn the prop of the plane in the photo with the starter and it doesn't spin. I removed the Glow plug and it spun fine with no rubbing. Is there a reason why this is doing that? Any help would be appreciated.
PS I also charged the battery fully.
Josey Wales 07-31-2004 07:49 PM
RE: Beginner Flight box advice.
Did you take the prop off the compression stroke first?
mrjones30 07-31-2004 07:58 PM
Yes I did.
TimC 07-31-2004 08:01 PM
Pull the rubber insert from the starter motor. Check the nut that holds the drive hub on to make sure it's tight. Snug it up good after applying a dab of Loctite. ( My Hobbico takes a 10mm socket ) Also you might try using your car battery to see if that will spin the engine. This will tell you if your flight box battery is bad.
Josey Wales 07-31-2004 08:01 PM
If the engine is inverted then you may have hydro-locked it..When you spun it over without the plug did you get a lot of fuel spraying out?
mrjones30 07-31-2004 08:36 PM
No,
I haven't taken it out on the field yet to start it up. I wanted to check and charge everything before I go out on the field.
mrjones30 07-31-2004 08:53 PM
After charging the battery for a few more hours I attempted to try it again and it spins the prop slightly. It's probably the battery that needs to be charged a little more. Thanks folks for your help.
fpdesignco 07-31-2004 09:28 PM
It sounds like your starter is not getting enough torque. What sized engine is this also what size spinner and prop
DBCherry 08-01-2004 06:35 AM
mrjones,
I would have suggested trying to charge the battery further. Usually requires a good 24 hour charge if it hasn't had one for a while.
Chances are the battery is on it's way out.
Dennis-
fpdesignco 08-01-2004 09:51 AM
yeah thats what im thinking too.
raideron 08-01-2004 11:04 AM
As DBCherry has said, Make sure your battery is fully charged..
If it still will not turn it, Your starter may be shot and you may
need another..
DBCherry 08-01-2004 04:30 PM
I'd try a different battery before replacing the starter though. It's more likely what's bad.
Dennis-
