Digital Servos?
I'm thinking about purchasing a Futaba 7 CAF for my ultimate biplane but I noticed for $30 more I can get 4 digital servos instead of the standard ball bearing ones. What's the difference between normal servos and digital ones? Would I be happier with going digital in the long run?
Thanks |
RE: Digital Servos?
Go for it..they have better resoulution, and better centering...
RE: Digital Servos?
and most probably more power - speed.
for $30 you would be mad not to get em |
RE: Digital Servos?
ORIGINAL: volkan and most probably more power edited this in for compairison. S3151 SPECS: Speed: 0.21 sec/60 degrees at 4.8V Torque: 43.1 oz/in @ 4.8V Dimensions: 1.59x0.79x1.42 in (40.6x20x36mm) Weight: 1.48oz (42g) S3004 SPECS: Speed: 0.23 sec/60 degrees at 4.8V 0.19 sec/60 degrees at 6.0V Torque: 44 oz/in (3.2kg-cm) at 4.8V 57 oz/in (4.1kg-cm) at 6.0V Length: 1.6" (41mm) Width: 0.8" (20mm) Height: 1.4" (36mm) Weight: 1.3 ounce (37.2 grams) Connector: "J" type with approx. 5" wire |
RE: Digital Servos?
I had the same question and went for the digital. The 3004's go for $14 and the 3151's go for $40 each. For 4 thats $100 difference minus the $30 difference in price. So you come out $70 ahead. I think thats a great deal.
RE: Digital Servos?
The servo's are much more precise than standard servo's. They are well worth the extra 30 samoliens. Only thing to know they use more juice than standard servos. So you should use a bigger battery. I would use nothing less than an 800 mah pack. 1000 to 1200 would be better. Good luck with your new radio.
Mark Shuman |
RE: Digital Servos?
Get hte digitals.
You may want to get a larger pack that standard, but other than that, you will enjoy the responsiveness of the digitals. |
| All times are GMT -8. The time now is 10:55 PM. |
