RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servo Compatability Hitec/Futaba???? (https://www.rcuniverse.com/forum/beginners-85/2252893-servo-compatability-hitec-futaba.html)
DragonHeart 10-14-2004 04:39 AM
Hi,
Just a quick question, i think ive just ordered some of the new Hitec HB-635HB with the wrong connection i think they have the JR/Hitec connection, but i plan to use it with a Futaba Receiver............. will they still fit and work ok ? or should i send them back or change the plugs myself if its possible ?
Thx.........
Campy 10-14-2004 05:00 AM
RE: Servo Compatability Hitec/Futaba????
Just make sure you plug them in properly and they will work fine. Futaba has a polarity tab on their servos and extensions. If you were going to put Futaba into HiTec, you would have to trim the tabs off.
phread59 10-14-2004 10:41 PM
Yup Campy is right. If I remember right, JR has a corner cut off one side. Just put the cut off where the tab would go on a Futaba plug. All should be well.
Mark Shuman
