Fuel Proof Clearcote
I am in the process of painting my Cub 1/5 by Sig. I have painted the the fuse with Rustoleum primer, Rustoleum enamal white & lusterkote sky blue. I want to fuel proof the paint with a clearcote. I picked up a clearcote by Rustoleum called "Crystal Clear Enamal". does anyone have any experience with this clearcote? also what would ya'll recomend as a clearcote that is in spraycan form. Thanks for the help.
sean |
RE: Fuel Proof Clearcote
I don't know for certain if the Rustoleum clear coat is fuel proof (resistant ). Some of their stuff is and a lot isn't. To be sure do a test panel.
Before you apply ANY of the clear coats do a test panel first. The clear coats MAY NOT BE COMPATIBLE with the paint. (The enamel/lacquer thing ). FWIW - MOST ACRYLIC enamel and ACRYLIC lacquer are fuel proof (resistant ) The only exception I have encountered to this has been a WATER BASE polyurethane. 2 coats of this is fuel proof (resistant ) to 10% nitro. It may be more, but all I use is 10%. MinWax does sell spray cans of this. Make sure it is the water base. The oil base WILL YELLOW over time, however, the waterbase does not yellow. Hope this helps. |
Klass Kote epoxy clear and 2-part auto urethane are both very fuel proof. The auto urethane is very expensive and extremely dangerous. Klass Kote is good stuff and I recommend it.
klass kote. where do you get it? is it automotive and being epoxy base isnt it heavy?
just wondering i have a Bud Nosen citabria I am putting coverite on and painting when i finish it (If i ever):eek: |
Have care when applying LustreKote over Rustoleum. They even advertise LustreKote now as a lacquer. The only Fuel proof Rustoleum I've found so far is gloss white and LustreKote will eat right through it. I won't use Rustoleum primer any more either. I use Krylon on all my sailboats and LustreKote when they are nitro powered. For Airplanes I choose LustreKote primer and paint or Coverite. I have an airboat that is white Rustoleum but had to put all the decorations on with Monokote trim colors because LustreKote ate through the Rustoleum.
| All times are GMT -8. The time now is 11:57 PM. |
