CA Help.
1 Attachment(s)
Please see the attached photo.
As you can see. I ran into a silcer problem. Now i need to remove the silencer and expoy it on. But I put a drop of CA between the bolt/nut. So, i managed to break the bond between the bolt and CA. But the CA is still just sitting there, acting as a stopper! How do I remove it. I doubt that NailPoish Remover will work. |
RE: CA Help.
Heat it up with a soldering iron, or just soak it in acetone. Good Luck!
RE: CA Help.
Try a heat gun or maybe even a small torch. I've used that method before to remove unwanted epoxy and CA.
RE: CA Help.
Hi.
Yes i thought about that. But im scared of ANOTHER fire! If you remember my Fire thread! There is fuel/oil every where. I have a miniture blowtorch. I could use that., but im scared[:-] |
RE: CA Help.
Don't use a torch, just an iron.
| All times are GMT -8. The time now is 09:43 PM. |
