Perry Carbs
I need to replace a mashed Super Tigre 90 carburator. Since I must replace it I wonder if I should consider a Perry carb instead. Thoughts anyone? Thanks
RE: Perry Carbs
I have used a couple Perrys on Super Tigers and they worked well. Only draw back is the high end needle valve. it is not long and easy to adjust but short and a bit of a pain. If the engine is exposed, then you'll be fine if not , you will have a problem. That is why I do not use them anymore. As far as the cost goes between the two, get the st and avoid the hassles
RE: Perry Carbs
MY favorite engines, HB engines came with Perry carbs. They tune a little differently than most brands, the idle mixture need only be moved a degree or two. Sounds very sensitive, but they are marked accordingly with a few hash marks and a "+" and "-" sign to remind you which way is which. They worked flaulessly for about a year or two, but then the rubber O ring needed replacement. A good friend at the local hobby shop wrangled a source of O rings and it wasn't an issue. I would however, check with Perry first and see if they have rebuild kits or at least replacement O rings available. And since my experience was nearly 25 years ago, the O rings may be made of a newer material that doesn't degrade and leak now.
RE: Perry Carbs
Thanks guys. I think I will just replace with a Super Tigre carb.
| All times are GMT -8. The time now is 02:23 AM. |
