RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   learning without an instructor (https://www.rcuniverse.com/forum/beginners-85/261073-learning-without-instructor.html)
troyp 09-07-2002 02:23 PM
All the posts on this forum say that you should use an instructor to learn to fly and even people like myself who dont have any clubs in the area are advised to somehow find someone who can teach us to fly. Im wondering what it is that can go wrong when learning to fly, I mean I can understand that someone who doesnt even know the basic principles of flight would need an instructor, but what about people like myself who have flown on computer flight simulators etc before. Surely it would be a simple matter of taking off, letting the plane gradually climb to a safe height and then practice turning etc.
Okay I know that sounds a little naive to think it would be that simple but assuming that you have everything setup correctly wont the plane climb to a safe height without to much trouble? Then you have plenty of space to practice and get used to the controls before needing to come in for a landing.
The question I am asking is what sort of problems have other beginners had when first learning to fly? What can and does go wrong when your first learning to fly?
Regards,
Troy.
Rcpilot 09-07-2002 03:16 PM
Go for it!!
Hey, I say GO FOR IT!!!!!!
All of us who advise beginners to get an instructor have no idea what we're talking about. We never actually needed an instructor either. We just did it to appease the old farts.
If you go ahead and fly the plane on your own; whats the worst thing that could happen?
You might get lucky and get it off the runway without breaking it or running it into someone. Then if you get it off the runway, it will surely fly straight and level and just climb gently to altitude without throwing you any curveballs, right? What are the chances that you might have the ailerons reversed, or the elevator reversed? Heck, I'll even bet a weeks pay that you'll have the balance perfect!!!!!!
Go for it buddy!!!!!!! YAAAAHHHHHOOOOO
It only costs about $500 to build a plane. You've got deep pockets and if you happen, by some unforseen reason, to crash it; just go get a new one, right? No problem.
I'll bet you can even land the sucker on your first attempt. After all, you do have extensive flight simulator experience. And any idiot knows that a simulator is "Just like the real thing". Flying a simulator has probably made you an expert pilot already, and you haven't even flown a real plane yet. Flying a real RC plane isn't all that different than a simulator. Just go for it!!!!!!!!!!
You might want to take a few pictures of your plane BEFORE you head out to the runway. Just in case something bad happens, and God forbid, you wind up taking the plane home in a trashbag.
Good luck. Heh heh.
Geistware 09-07-2002 03:37 PM
Get a knowledgeable flier to trim your plane and make sure everything is sound. As far as learning, get Realflight G2 and be able to land on the runway 10 out of 10 times with all the planes. If you can do that, you are competent. What I did was practice taking off, doing a stall turn, then land. Take off again, tail slide, and land. I could do this 8 out of 10 times, then I started flying the trainer. Nerves were my only issue. Flying as a breeze.
TIGER2PLANE 09-07-2002 03:41 PM
If you want to fly, you can. But the reason you need someone close by that does, is the NEWBIES always try to fly in the next town, while they are still home, more planes have been lost to them being to far out and cant see what the bird has done before it finds the good old brown stuff. Or when you are doing a low approach and you want the bird to go left and it GOES RIGHT, because you feed the wrong control into the bird.
I did learn to fly on my own...... I had a bird that was strong at staying together. I landed on top of a barn, into the side of a hanger, through a tree more than once, in to a tomato field but I learned to fly by my self. this only took 3 months to do. Just have fun and take your time at this and you will be alright After all I SOLO-ed on my first flight. LOL
LEDZx 09-07-2002 03:56 PM
Troyp, i am also learning to fly without an instructor, and it's very daunting, especially on an old bipe ( tail dragger).
I have done a few high speed runs , almost took off, just to get the hang of it, but after a while I realised this plane is just too advance for a first time r/c pilot.
I m sure i could handle it, but its balsa and my thumbs aren't so experienced.
I have flow full scale Cessna 172s and microlights and turbine helicopters ( Alouette 2 ) fine on my first flights , but i sense something about these little planes, especialy the minimal response times.
A month or two back I was doing circuts on a Super Stick of my friend's, I found it OK, but wasn't happy about landing these things, in all I have flown 5 times.
Just the other day i found that I had some PVC pipe, and I am now in the late and finishing stages of building, these are semi-indestructable and 'ok' for learning on, not the best bye any standard. I chose to build the DPS, Das Plas Stick.
I feel my confidence growing, hopefully I won't become 'cockey' as they say. But I will be going solo on this spad and I think i will be able to do it now that it is a trike gear configuration, not as trickey as a tail-dragger.
Anyway, good luck for your endevours, I just wanted you to know that your not the only one in your situation, give me a shout if you want some advice, and I will keep you informed on my progress,
Cheers troyp,
LEDZ
rovmanuk 09-07-2002 04:39 PM
I say good look if u want to try, i hear getting it down is the difficult part. anyway "Rcpilet" no need for all the sarcasm you coulda been a little more polite.
Also troyp, just check all the controls on the ground and make sure they function correctly for your given inputs.
MikeL 09-07-2002 04:39 PM
Once it's taken off, you can't just let it climb. You're going to have to make a turn fairly quickly. That's not going to be as easy for you as you might think. For one thing, it's uncommon for a model to take off and fly straight and level. You mention it being set up correctly. Without an experienced eye, how do you know? Even if it is set up correctly, you're going to have to trim it out yourself. Trimming is something that takes a somewhat practiced hand. That plane is going to bank, pitch, and yaw without you making any control input. That's because there are subtle flaws in the design and in the build that require correction in the air. If you don't know how to quickly and accurately make those corrections with your trim levers, you're in for a world of hurt.
I don't think you comprehend just how quickly things happen when you're flying. Once you've learned, you don't think, you just react. In you're position you're going to have to race to think ahead of the model. You'll get behind it, and that's when the trouble begins. You're not going to have as much time as you think.
Are you used to the control reversal as the model flies towards you? Nobody is going to be there to mention pushing the stick towards the low wing. It's easy to say you'll do that yourself, but when it's up there you'll find yourself in a different state of mind.
What about the engine? How much experience with glow do you have? If it deadsticks, what will you do?
torque_roll 09-07-2002 06:56 PM
An instructor helps a lot when learning to fly. Sims are a lot different than flying a real airplane. They are a lot easier to land and take off.
Instructors are there to make it so you don't crash.....and to help you learn to be a good pilot.
A lot of people learn w/o an instructor, but they usually crash a few times before they are succesful.
I would say that having an instructor is a definite plus.
Have fun and good luck.
gpmikemorse-RCU 09-07-2002 07:09 PM
Re: learning without an instructor
In addition to what's been said, flying the airplane is only a small part of the learning process. For most newbies at our club, the first hurdle is assembling the plane so that it is flight-worthy. The next big hurdle is getting the glow engine to start and run reliably, and doing so in a safe manner. The third part is understanding everything it takes to fly safely. None of these can be learned on a sim. Most people (me anyway) learn things one at a time, so it's really nice to have an experienced person take care of all these things while you concentrate on learning to fly.
The advice about not going it alone applies to the typical .40 size glow-powered trainer made out of wood, because they are relatively fragile. If you have to go it alone, I would recommend either a park flyer, or an indestructable plane like the U.S. Aircore or the spad.org Debonair.
On a related subject, I was quite impressed to see that Hangar 9 is addressing the engine learning curve. According to their advertisements, they are now selling engines that are already broken in, with limits on the needle valve, and other features to make them easy for newbies to run and keep running. Yea Hangar 9!
Three 09-07-2002 07:13 PM
I learned to fly on my own with no one around. After busting up two nice trainers, I realized I needed help or a plane that could stand hitting the ground. So I got a Sturdy Birdy. I crashed that thing about 30 times but was able to get back in the air right away every time. I definitely learned the hard way. What everyone is telling you is true, especially "MikeL".
Good Luck
troyp 09-08-2002 12:09 AM
Thank you everybody for the advice. RCPilet you did not need to be so sarcastic, I did not say that I am good and I do not need an instructor I was just asking what problems can occur when first trying to fly. MikeL answered the question perfectly and gave me a good insight into what I can expect if I go it alone. Unfortunately I do not have a choice as I live in a remote town in the North West of WA so we do not have any clubs etc here. But I might be able to find a fellow flyer that can perhaps teach me.
Troy.
TerrellFlyer 09-08-2002 12:43 AM
Hi troyp,
no, you probably didn't like RCPilets answer,but it was truthfull,my aswer to your question is, hurt yourself,hurt someone else,crash,crash,crash,and crash again.If you don't run out of money and patience,you can learn to half a** fly,facts of life.
Have a goodun,John.
MikeL 09-08-2002 12:48 AM
Troy, have you thought about taking a day trip to a more populous area to get some instruction? You seem motivated and knowledgeble, so an afternoon's worth of stick time might be all you need to get you up and running. Consider the amount of time and money you've put into this project, and the enjoyment you stand to get from it in the future.
whstlngdeath 09-08-2002 02:16 AM
idiots
It's idiots like "Rcpilet" above, who can't even spell pilot, who give
this forum a bad name. Hey, get a life and try and help someone
for once.
troyp 09-08-2002 03:25 AM
MikeL,
A day trip for me to the nearest town is Pt Hedland which is 600 kms away (About 300 miles). They do have a club there as I have seen thier website. I have heard of one or two people in my town who have planes and although I do not know them I might try and get in touch and ask if they wouldn;t mind helping out.
Thanks agan,
Troy.
KCFlyBoy 09-08-2002 03:37 AM
I have a cousin who taught him self to fly he had a duraplane it is not indestructible but it did manage to survive until he could fly. I would suggest real flight simulator first to get the feel for flying. If you can find some one to help you do it you will save your self a lot of trouble, pain hassle and Money.
Ghostbear 09-08-2002 03:41 AM
In my experience
As a recently soloed pilot (after 5 flights on the buddy box), let me add my 2 cents.
If you can't find an instructor, start with electrics. You CAN learn to fly a parkflyer with just a sim and a lot of glue. You could then move up to more and more advanced electrics and maybe safely fly a gas trainer without an instructor.
However, in my experience, DO NOT underestimate the difficulty in:
1) Getting the engine to run right. If your a novice, dead stick can equal dead duck. You may get the engine to run ok on the ground, but once she's airborne, all bets are off. I still get someone to check the tuning of my engine.
2) Trimming a gas trainer. I was flat amazed at where the flight control surfaces ended up after the ship was trimmed out. Setting them flat and level by eyeball was practically wasted time. On her maiden flight, she started rolling badly to the right and pitching down. Fortunately, the club president did the maiden voyage and got her up high enough to trim. I'd have lasted about 12 seconds.
In know this is a gas-oriented forum, and it is rare for anyone on these boards to admit electrics might be a valid option, but if you really can't get an instructor that's what I would do.
Good luck,
GB
KCFlyBoy 09-08-2002 03:54 AM
I have to agree Electrics are a good starting point. I have a Mini IFO my father in law was over a few weeks ago. The winds where calm and I wanted to fly so I asked him if he wanted to watch he agreed and we went to the back yard. I flew it for a while and asked him if he wanted to. He said he was afraid of crashing it and breaking it. I let him know it was about as un breakable as a plane could be. He flew and crashed and flew again he is in his 70s he had a great time. After a few batteries he flew it into the pave stone wall beside my house. The stone cut the front bow. My father in law apologized several times for breaking the plane. I told him to stand still and I would be back. I grabbed the ca and my my magic dental floss and he was flying again in two minutes.
k2jkk 07-27-2003 12:27 PM
Troy, I learned to fly by myself and found it rather easy. You MUST have a plan. You MUST have a Biiiiig flying field. You must have a model that can fly by itself in little or no wind. DO NOT teach yourself to fly if you have access to a club and an instructor.
Woodpile 07-27-2003 01:02 PM
Another dissenting opinion
Troy,
While learning with an instructor is definately the better option, in your case it seems extremely difficult to get any decent amount of stick time in. RCPilet is an idiot and a poltroon. I taught myself to fly and I have never owned or flown a kit plane, ARF or RTF. Everything has been built from scratch and everything has flown.
Now don't get me wrong. The first attempt was crude and would have been trashed eventually anyway because it was not right, but I had a remote area to fly in so I wasn't worried about hurting anyone but myself. Remote areas sound like your forte`!
You have to resign yourself to the fact that you WILL crash! I went through 4 incarnation of the same plane before I logged my first (wheels on the bottom) landing. As long as the radio gear and engine survive, it does not cost $500.00 to build a plane. More like US $75.00-100.00 depending on the complesity of the plan and covering scheme. I have the plans for the very basic high wing trainer that I have been using. It's a .40 sized aircraft that I scaled up to .60. Bigger is definately better.
Probably the best thing you can do is buy and fly the hell out of an RC simulator. I have RealFlight by Great Planes. It made all the difference. It is not perfectly realistic, but it is good enough. I put about 30 hours on it and went out to fly my plane. Aside from hyperventilating a bit and getting sweaty palms, everything went extremely well and worked just like the program did. The problem with the simulator is that in order to keep oriented on the field, you have to fly low enought to see the ground. You have no other periferal vision and no sense of where you are in the pattern. Fortunately, flying low sharpens your reflexes... hehehe.
Anyone who says you can't learn to fly without an instructor is full of a bucolic endproduct fabled in song and story. The first guy to fly RC did it, with much cruder equipment than we have now... What they are saying is THEY couldn't have learned to fly without help. As I said, it is cheaper and safer, if you live in an urbanized area, to have an instructor. It is always easier to have someone give you hints and tips than it is to figure everything out by yourself. You wind up re-inventing to wheel and sometimes do not learn of things others know. On the other hand, if you have a bad instructor, well no one seems to want to talk about them. I guess they just don't exist...
Do your thing and if you are able to accept the fact that you will have some midair collisions with the ground, go for it! Nothing gives you a sense of satisfaction than doing it yourself, especially when everyone tells you it can't be done...
Post you progress and let us know how you're doing.
Cheers!
Ed
jettstarblue 07-27-2003 01:06 PM
Oh Boy
Troy,
I believe you have been given the full gamut of advice here, so make the decision for yourself. I for one, have taught myself to fly, and now I instruct.
It didn't cost me a fortune, I didn't kill anyone, I DID get a few extra hours of "building experience", but it can be done.
It sounds like you live in a fairly remote area, so finding a LARGE open space should be easy.
You will probably want to start out with a "park flyer" type, or if you want to go with a gas plane try a sailplane w/a Cox Black Widow, or Texaco endurance enginge, or better yet, a Norvel- better, cheaper, and has a throttle. I can buy the .049 w/throttle for 30.00 near where I live,(new in the box) so if you need an inexpensive engine, I may be able to help.
The biggest single thing is this,
IF YOU THINK IT'S FLYING TO FAR AWAY, FROM YOU- CUT THE THROTTLE!!!!
IF YOU THINK IT'S GOING TO CRASH,-CUT THE THROTTLE!!!!!!!!
IF YOU AREN'T SURE WHAT'S GOING ON, CUT THE THROTTLE!!!!!!
And finally, turn your body so you are always facing the direction the plane is flying, you won't be confused by the control inputs when the plane is " flying toward you"......
Walk before you run, or glide before you fly...........
Feel free to e-mail me with 1001 questions[email protected]
I have time, and patients.
Jetts
Ken Bryant 07-27-2003 01:30 PM
YES, you can do it
Let me be the first to say that YES, you can learn on your own.
First and best investment is a quality flight sim program. Something like Real flight G2. When you do fly RF G2 purposly screw up the trims and reset them your self. THis will help you when it comes time for your real plane.
Next, read and ask 100,000 questions here and other places. Get the lowdown on everything.
Get a good quality trainer. I just soloed my Sig LT 40 ARF. I soloed on my first flight today. I have a good background in RC and have been flying RC Choppers for 3 years. I am also self taught in them.
You can do it, just take your time and have LOTS of patients.
David Cutler 07-27-2003 05:20 PM
Hi Troy,
It's all a matter of skill that can only be acquired with experience.
For example, you know what to do to get a note out of a piano , right? You just press one of the keys. Now try to play a tune, even a simple one. It's not that easy, even if you know everything there is to know about how a piano works.
When a plane flies overhead, it's no use knowing what would correct it if it turns left, you have to actually do it, using the finesse you have built up over the times it happened before.
Things happen very quickly when you are flying, and you can't stop for a breather, like when driving a car!
And here's the main point:- Even the best pilots in the world would almost certainly crash if they lost their 'finger memory'. You know that .. it's the thing that makes you do things without thinking. Just imagine trying to ride a bike if you had to remember all the time how to balance on it.
One further thing. If you have been learning on a simulator that puts you inside the cockpit (like the Microsoft ones) they are almost useless at teaching you how to fly a model, from outside the plane. There are a few commercial jet airline pilots in our club who were just as hopeless as anybody when they first flew a model! A model airplane simulator like the Realflight G2, however, is a great way to learn the finger memory skills.
There's no hurry. Every challenge you face will be satisfying to overcome. Just enjoy!
-David C.
impulse 07-27-2003 06:21 PM
Re: Go for it!!
Good luck. Heh heh.
Do i note sarcasm? lol.
richard1967 07-27-2003 07:43 PM
dont fly alone
hi just to say im new ive flown 6 times i go to the club twice a week under instruction and believe me ive flown flight sim aswell its not the same these rc flight sims are crap i got into lots of trouble dead stick,and losing control i.e losing consentration it does take alot iout of you please get some help they are right you need for them to set the plane up for you check to see if its flight ready you dont want to crash your plane ive seen crashes and there not nice dont destry it after a few mins flying even gettin off the ground is hard work you have to take off in the wind and land in the wind your engine has to run just right please get some help ive heard alot about first time fliers without instruction and they all crash good luck there could be a club or a location where the fliers go to even send a letter top your local paper put a post in it asking for other fliers for help and its nice to have a instructor there to take the plane off you when you start to panic it does luck easy but its not
