Elevator + Tail wobble
Hey guys,
i have just finished running a tank of petrol thru my Kyosho Calmato and while i was watching it i noticed that my elevator and tail had a good deal of wobble in it from the engine vibrations. I was just curiouse as to weather this cause pose as a problem during flight. If it would cause any problems how can i fix it before i crash? On a differant note, what would be the best way to fix my receive batteries and my servo receiver to the plane? At the moment i have them just sitting there flapping round in all the engine vibrations and i cant think this would do them any good. Cheers Phil. |
RE: Elevator + Tail wobble
As for the the tail vibration. A lot of that is normal. What isn't normal is looseness in the control surfaces. make sure that the rudder and elevator surfaces don't have any slop in the movement, because that will translate into flutter in the air. But the entire tail vibrating is normal.
As for your receiver and batteries. Wrap them in foam rubber and put a rubber band around them to hold the rubber on. Then I set small eye hooks into wood blocks epoxied into the fuselage where you want to mount the receiver and battery. Then use rubber bands hooked to the eye hooks to hold in your receiver and battery. This set up will cushion the components from normal vibration, and will protect them in the event of a crash. Hope this helps. |
Ok glad to hear that the wobble is normal, i was moving the tail and elevator and the seemed to be tight, not that id know what loose was but they looked normal.
The idea for the receiver and batteries is good! Ill have a look inside my fuselarge and see what i can do, thank you :) |
Hey Phil, when are you gonna bring that sucker to the flying field:D:D:D
Terry |
Well i have this saturday off so i thinking of taking a trip over then. Will you be there then?
Another way you can secure the battery and receiver is:
Wrap them in foam and secure the foam with some masking tape. Then use a couple of strips of self adhesive velcro - one on the receiver/battery, the other on a suitable surface inside the plane. I use this method on my planes and even though I have had some hard crashes :eek: They have only come loose once. FWIW - I usually mount my battery IN FRONT of the receiver. In case of a crash, I don't want the battery to plow into the receiver if it should come loose. |
Phil,
Yep, planning to take the SIG SE out for a few gentle circuits on Saturday:D Be good to see you out there. Terry |
WOBBLE is NOT acceptable on a flying aircraft of any description. In your case you should "cage" the vertical and horizontal stabs, all around.
By this I mean attach wires or strong threads to both sides of the vertical and to both sides of the horizontal stab and link them together. For reference look at the tail of a Piper Cub or similar. If you don't I have a slight "feeling" that the CLAMATO won't be around too long. Even downunder. |
Phil,
Assuming that there is not a design flaw in this model (I'm not familiar with it), and assuming that you have put it together correctly it should not be necessary to add extra bracing. Its hard to make a call without seeing just how much the tail surfaces are vibrating. If you are able to get out on Saturday someone will give the plane a check over. If it checks out and there's an instructor around you could be flying:eek: Terry |
It is comforting to see that the RUSH TO FLY NO MATTER WHAT syndrome is also alive and well in Australia.
ADVISE, in my opinion, when given should TEND towards cautioning somebody, not pushing toward the abyss. I guess the premise of : it's somebody else's plane so who cares..... applies here |
J3FAN
I suggest that you read mails before you jump back with a reply. You will then note that what I suggested was that he bring the plane out to a flying club where it could be checked over by experienced fliers. I am not sure how you interpret that as being a "rush to fly no matter what". If there is a problem a check over should get to the root of it, rather than trying to patch over with wire or thread. |
Begging your pardon sir, i would like to inform you that i bought my plane in August of last year, that is one two three four firve six seven months ago now. Im only eager to fly now as i feel i have sufficiantly done everything right. If there is a problem then i will be more than happy to wait another week and make sure my plane dose not land nose 1st and at full throttle :)
I do hope that there is nuthing wrong with it and all the vibration is normal and that im just being a big worry wart! Terry what time do you get out there usually? |
Phil,
I usually get out about 10 and stick around until 2 or 3 as long as the weather is OK. Morning crew drifts away about midday (early birds already been there a couple of hours), then there's usually a smaller afternoon crew turns up. As I mentioned in an earlier mail you will need to get through the gate or walk a way. Happy to assist you getting in if I can, mobile stays in the car when flying so this not much use. What time do you plan to get there? Terry |
i was thinking of getting there early but if you are going to arrive around 10 maybe i can try to arrive at about the same time so i wont be so lost and nervouse :P. It should not take me to long to get to im thinking maybe a45 min drive, thats if i dont get lost hehe :P
If im there and i cant get over the gate, do i jump the gate with my plane and gear or leave my car there and jump the gate and find you or sumone else? This is quite nerve racking :P |
Phil,
Best plan is to leave the car at the gate and walk across to get someone to let you in. If you turn up earlier with luck you could find someone going in at the same time One time I forgot my keys on a weekday and walked it with a plane in one hand and my flight box in the other. Definitely would not recommend it. 45 mins is about right from Hornsby, maybe a bit longer depending which side you are. Hopefully the weather will hold out, didn't fly last weekend so the thumbs are twitching! See you Terry |
Morning Terry,
I will do as you have said, should i ring the club president and speak with him before hand as well? I was thinking of buying a flight box because it will take many trips back and forth to my car to bring my transmitter my starter batteries for starter and glow starter and fuel, what sort of box are you using? Sorry for asking so many questions i hope you dont mind :P Cheers Phil. |
Phil,
No need to ring, just turn up, you'll be welcome no prob. SRCS is a pretty relaxed place to fly as long as you follow some common sense rules. Sat am there should be some committee members around that can give you info on joining. I use a home made flight box cunningly designed by stealing ideas from others. You should be able to take a look around what others have and see what suits you. No prob with the questions, happy to help Terry |
Hey Terry,
Thank you for all your answers and help! I am very excited to get out there now :)!!!! |
ORIGINAL: Redback I use a home made flight box cunningly designed by stealing ideas from others. Terry bushman, vibrations are normal but too much shaking isn't good. the calmato is an excellent flyer and i've maidened several for friends and buddy boxed even more at the flying flied... i not only love the way they fly, i love the way they look! just to make sure, you did epoxy the wings, right? i've flown some that didn't and although nothing happened, i wouldn't recommend it. epoxy everything!!! (um... other than the CA hinges) |
Hey forestroke,
Im glad to hear that the calmato will fly well, i was a little nervouse cause i had not herd any1 really talk about them on here. I did epoxy everything i had to put on apary from the landing gear, do you think i should epoxy that on as well? I hope i did a good enough epoxy job on the wings as well! Cheers Phil. |
no... keep the landing gear bolted on :-) but you can epoxy the block from inside since that is generally a weak point on ARFs though i have to say none of the calmatos i've seen have had a problem with the main gear blocks.
it is an easy flyer and the only time i've had trouble flying one is when someone was yelling for help because he couldn't get the plane down. we fly off pavement so landing speed is important. he hadn't adjusted the engine idle and so the idle was quite high. couldn't cut the throttle either since i think there was a leak in the carb (GMS .47 engine that wouldn't quit and until you literally threw in the towel). he had taken it around half a dozen times and couldn't get it to stay. i had to take it around twice to get it slow enough to land safely. many people try to cut corners before their flight. if a plane won't idle low, that's okay... but make sure it can shut off. it is critical to safety. if the engine is running inconsistently don't just make sure it doesn't die at full throttle and tell yourselves to make a mental note not to move the throttle too quickly. so many "accidents" could be preventable. the calmato is an excellent plane and so easy to build. it was my number one recommendation as a trainer. that has since been replaced by the world models raider mach 1 because of price. |
This is all very good to hear and is helping me with my confidence, i just ran another tank of fuel thru it and at full throttle there isnt to much wobble, only alot when it is idleing just above stall, i think the wobble yesterday was due to the way i had it secured to the ground.
Hopfully on moday fourstroke, i can let you know how my 1st flight went :)!! Cheers Phil. |
i hope that you will be buddy boxed! i'm sure terry can do the honors of the maiden and then buddy box buddy...
um... not that i know terry... |
here are a few pics of my little kite
[img]http://i2.photobucket.com/albums/y4/...n/Dsc00569.jpg[/img] [img]http://i2.photobucket.com/albums/y4/...n/Dsc00568.jpg[/img] [img]http://i2.photobucket.com/albums/y4/...n/Dsc00567.jpg[/img] [img]http://i2.photobucket.com/albums/y4/...n/Dsc00570.jpg[/img] [img]http://i2.photobucket.com/albums/y4/...n/Dsc00572.jpg[/img] |
Phil,
Looks a nice job but you will need to secure the battery. If you wrap it in enough foam it should hold inside the fuse. Where's the Rx switch? Normal place is on the fuse side away from the muffler. Also, did you fit some short lengths of fuel tubing on the clevises to stop them popping open? I'll try and remember to bring a few extra bits on Saturday just in case. BTW, don't forget to bring the big flat thing that fits on top:D:D:D Terry |
Hey Terry,
I have that white soft foam stuff, it came in the box if i wrap it in that and them masking tape it up, same with the RX will that work? i bought sum velcro incase that route is needed. i was going to put the RX switch on the other side to the muffler in the black area just under the wing, but i havnt done that yet. Nore have i put tubing over the clevis because i did not know i needed to[&:] I have noticed that when i take the tubing to the muffler off it rips instead of just pulling off..... I ave sum work to do :D |
bushman - the plane looks pretty and the installation looks good. only thing is the throttle looks like it could hit the elevator servo. should cut it to ensure there's no interference. also, have you checked the CG? your rx and battery placement would depend on it. since you have a very light engine there, you may end up needing some nose weight. i'm not a big fan of the LA series of O.S. engines but if you've got it, no problem but you'll most likely be a little light in the nose.
terry, it doesn't look like there's right thrust on that engine. have a look. looks like it's pretty much dead center. |
Hey fourstroke,
i havnt checked the C of G yet i was going to do that after i had secured where the rx and batteries will go. I think i may need to add a little nose weight but i am hopping it will work out ok, using the finger method should work? Cheers Phil. |
just on the right thrust, what is that, i have never herd of it before is it good or bad? will i need to mod it?
you have it reversed, you should mount the rx and battery based on the CG and try to add as little weight as possible. by putting the battery even next to the fuel tank, you can save some weight which will ultimately help the flying characteristics of your plane.
first take the wing and put two small stickers on the underside where the CG should be based on kyosho's recommendations. these should be just large enough for your fingers to find and be 1"-2" from the fuse on either side when you mount the wing. empty the gas tank - CG should always be adjusted when the plane is at it's lightest fuel load. the plane need not be bone dry but suck as much fuel out as your pump allows. now mount the wing with the rx where it is now but take out the battery. try to balance the plane at the CG by placing the battery pack forward and backward along the fuse of course on top of it. when you find the right place, take off the wing and mount the battery pack. remount wing and make sure it is level when your fingers are one the CG or the nose is ever so slightly lower. |
forstroke,
Sounds easy enough, lucky i didnt do it my way i woulda just added usless weight to my plane. Ill try n get it done tonight or early tomozza. Cheers Phil. |
right thrust - generally a plane is built with 2 degrees of right thrust and 2 degrees down thrust. the right thrust is to compensate for the torquing of the motor which will pull it left at any amount of throttle. 2 degrees usually allows the plane to track straight at speed. the downthrust is so that a level flight, the attitude of the plane is a little pitched up (for lift) while the propeller is still pulling it parallel to the earth.
i'm sure some others will chime in to agree or disagree! i'm sure that kyosho wouldn't make a blunder like that. the only thing is that if you purposely straightened the engine inside the mount instead of allowing the two rails to dictate the angle of the engine and drilled based on what you saw was square then you might have some problems there. but if you just put the engine on and adjust the rails so that it hugs the body of the engine, then drill and mount... shouldn't be a problem. |
fourstroke,
The engine mount came pre mounted all i did was tighten it up then set the engine on it, so hopfully that should make it all ok. Cheers phil. |
ORIGINAL: drunkenbushman just on the right thrust, what is that, i have never herd of it before is it good or bad? will i need to mod it? |
you mean you didn't need to drill holes in the engine mount? it uses the flexible engine mount where you have aluminum straps?
Phil,
Something I should have asked you earlier, did you get your Tx bandwidth checked? I'm not sure what the rules are at SRCS, at Coffs Harbour where I also fly a visitor can use a double width key as a short term. Hopefully we can sort something out if you haven't had it done. Don't forget to charge your batteries!!! Not sure about the white stuff you have for packing the Rx, I have have some foam I've put out to bring along in case needed. There is a fair bit that can be sorted out at the field, however there is also a chance that something will need to be done that can't. Better to take home an intact unflown plane than a broken flown one! Having said that, if we can get you into the air safely we will!! Terry |
ORIGINAL: forestroke you mean you didn't need to drill holes in the engine mount? it uses the flexible engine mount where you have aluminum straps? Hey Forestroke, i did not need t drill any holes for the engine mount, there was a plastic one on the plane and i just put my engine on that one..... |
ORIGINAL: Redback Something I should have asked you earlier, did you get your Tx bandwidth checked? Don't forget to charge your batteries!!! What is or how do i have my Tx bandwidth checked? That means that i havnt done it :P so how do i do it? Cause im guessing i need to have it done, and i dont have the rechargeable nicad batteries but i am taking a trip down to wings n things tomozza so i might buy a set for my TX. cause atm i have energizer batteries in both. Cheers Phil. |
bushman - that's good. well good luck this weekend! i hope the weather in taiwan cooperates... i'm having flying withdrawals after nearly a month without flying!
Phil,
You can get a bandwidth check through Wingsnthings but I think that the guy only comes to do it last Thursday of the month or on a full moon or something like that. Hopefully we can work out something temporary for tomorrow, will need to check what the rules are though. I would recommend getting Nicads, not least because I have no idea how long alkaline cells would last in a model. I have a spare Rx pack, I'll try and remember to charge them and bring them along. My planes are on charge now so the charger will be free tonight. Just noticed that your radio is Futaba, mine is JR. Not sure if the battery connectors will hook up, I know that you have to play with Futaba servo connectors to get them to fit JR but never played with the battery connectors. Terry |
| All times are GMT -8. The time now is 05:00 AM. |
