RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   2 Rubber Bands are Plenty (https://www.rcuniverse.com/forum/beginners-85/2761328-2-rubber-bands-plenty.html)
TimC 03-13-2005 06:03 PM
If you want an interesting flight, try only two rubber bands. I was putting the wing on my Aircore and installed the wing with only two, then decided to make sure the ailerons worked before adding any more. The ailerons worked so I finished the pre-flight, fueled it up and took off. The wing lifted and changed the incidence, making the plane climb like crazy. I realized immediately what was wrong and very slowly and carefully throttled back and brought it around for a landing. Those are sure a good brand of rubber bands. :D
DaveB 03-13-2005 06:25 PM
RE: 2 Rubber Bands are Plenty
You got away with one.
DaveB
Pilot Chad 03-13-2005 06:33 PM
What kind of bands....? lol You got LUCKY
exeter_acres 03-13-2005 06:46 PM
Dare you to try and figure out a way to just use 1!!:D
Live Wire 03-13-2005 07:15 PM
Sig's #67
Sukhoi_Madness 03-14-2005 04:53 AM
Often wondered about what would happen... [8D]
CHassan 03-14-2005 05:24 AM
I watched a guy take off with a dozen or so rubberbands, had way to many high g pull outs (full power straigh down.. bend the stick back type pull outs) had audible clues many rubberbands were breaking, then landed with about 3 or 4 bands still on!!!!
