RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Glue (https://www.rcuniverse.com/forum/beginners-85/279589-glue.html)
pajda 09-23-2002 04:05 AM
Glue
Need to thin epoxy so that it would penetrate loose joints around assembled fire wall. Should I use aceton or alcohol? Thanks. :confused:
Braindead_Ed 09-23-2002 04:21 AM
Glue
try both on a piece of scrap and see what works best
thats what i would do?
stomper 09-23-2002 10:12 AM
Glue
Hello Pajda
Use 20-30 min. epoxy and thin with a little acetone.
Hope this helps.
Doug
KCFlyBoy 09-23-2002 10:44 AM
Glue
Either one will work I like alcohol better than acetone and less smelly.
pajda 09-23-2002 11:29 AM
Glue
Thanks for help! pajda
Rodney 09-23-2002 02:18 PM
Glue
Your best results is to not use any thinner, use 30 minute epoxy and, after putting it on the area, heat the area with your heat gun. You will see the epoxy suddenly get thin and wick into every nook and cranny. Don't get it so hot is bubbles, just hot enough to suddenly run.
gpmikemorse-RCU 09-23-2002 03:11 PM
Glue
I recommend using epoxy that comes thin to start with. It's usually called something like "Epoxy finishing resin".
