How do you estimate height?
Just curious how people estimate height. A telephone pole is 30 feet, but that's all I have for reference.
RE: How do you estimate height?
Just curious as to why you need to get a heigth estimate?
I normally take a wild guess, after about 150 i have no idea.
ORIGINAL: efergie72 Just curious as to why you need to get a heigth estimate? |
ORIGINAL: paul_c ORIGINAL: efergie72 Just curious as to why you need to get a heigth estimate? Fly-guy |
ORIGINAL: Fly-guy ORIGINAL: paul_c ORIGINAL: efergie72 Just curious as to why you need to get a heigth estimate? Fly-guy |
Height and distance are the most difficult things for a person to judge. I have heard of people saying " I flew my model to 2000 feet the other day". I would suspect that most people would overestimate height. I have flown over my model field at 1500 feet and the models on the ground were little specks. Way to far away to control properly.
Our runway is 200' long, so I try to visualize the number of runway lengths (or fractions) above ground. Crude, but it works (I think).
Estimating hieght and or distance accurately usually requires a reference. Britbrat uses the runnway I use the tree line surrounding the field.
ORIGINAL: britbrat Our runway is 200' long, so I try to visualize the number of runway lengths (or fractions) above ground. Crude, but it works (I think). |
ORIGINAL: Crashem Estimating hieght and or distance accurately usually requires a reference. Britbrat uses the runnway I use the tree line surrounding the field. |
For sailplanes I have seen people use reference cards that they hold at arms length. You match the picture on the card with the apparent size of your sailplane and it gives you an estimate of the height (or distance from you). I think they made these cards up themselves. I don't know if they can be purchased.
You could easily do it by setting the sailplane on the ground with its nose toward you and measure out a distance like 100 feet, then hold up an index card at arms length so that it looks to be just under the plane and mark the ends of the wingtips on the card and write 100 feet under it. Repeat for other distances. Not too accurate but it's cheap. |
I haven't got a plane yet but a piece of advise I heard was to fly as high as you can comforatbly see the plane. Meaning still being able to tell the direction and not give you neck pains when you do venture closer to your position.
The guy who told me that was training someone that day. The plane was some high wing homebuilt trainer that had a 76" wingspan and the plane looked as small as a parkflyer they had it so high.:D I think that'll be my rule of thumb when I start crashing... err, flying. |
ORIGINAL: Commander_Drake For sailplanes I have seen people use reference cards that they hold at arms length. You match the picture on the card with the apparent size of your sailplane and it gives you an estimate of the height (or distance from you). I think they made these cards up themselves. I don't know if they can be purchased. You could easily do it by setting the sailplane on the ground with its nose toward you and measure out a distance like 100 feet, then hold up an index card at arms length so that it looks to be just under the plane and mark the ends of the wingtips on the card and write 100 feet under it. Repeat for other distances. Not too accurate but it's cheap. Thank you all, good info. I like Commander_Drake's idea. I might try this with a slow sailplane that I'm getting; any other plane might be too difficult (I usually need both hands on the controls!) |
As you can see, most people use the WAG method. In all realistics, if you don't use some sort of data recorder that uses a GPS or something to measure dist acurately, you won't be close. I have had people call the tower many times when I am doing jobs over town and they always say we are 50 feet above their roof. The tower usaully tells me about the call, but I am on radar and am at between 1000 and 1500 usually.
Very very few can accurately judge distance when it gets more than a few feet from them. |
Golfers are pretty good at measuring horizontal distances. I can tell when my plane is a 5 iron away.
ROFLMAO BRIT BRAT :D:D:D
ORIGINAL: britbrat Golfers are pretty good at measuring horizontal distances. I can tell when my plane is a 5 iron away. Never thought of that, but then when I go to a new course, I suck at it again, so I think it goes back to the point of ref. I know the course pretty well at the lake, so I can do it well there, but the ones here, I can never get it right because I only play them once or twice a year. the 150 bush moves every time I get to it so I can never hit the green. Yea, thats it. :) |
The problems come when it's in an inverted flat spin -- a lob-wedge high.
britbrat, I would say a wood tee high and many of them:D
The tee-high stuff is for low-inverted passes -- but ya gotta stay awake.
ORIGINAL: britbrat The tee-high stuff is for low-inverted passes -- but ya gotta stay awake. But your rudder can only be 3 paint thicknesses from the ground on that pass. [8D] |
Agreed:D
If you spot a tall communications tower drive to it, if possible. The tower owner and a tower number will be on the fence. You can then use your friendly Internet and Google to find the company and the data for that tower. I found that the one behind my office is 540 feet tall. I look at it frequently and try to take that reference to the flying field.
Our flying field is within a couple of miles of an airport. Purportedly, we are supposed to not fly over 400 feet (and so you know that never happens.) This has lead to several discussions at the field about how high 400 feet was. So when I'm on break behind the office I studied this communications tower that is approximately 1/4 mile from the office. One day we used a laser range finder and trigonometry to estimate a height of just over 500 feet for the tower. I didn't believe the estimate - I didn't think it could be that tall - but we rechecked the calcs - and eventually I drove over to the tower and got information from the gate that enabled me to look the tower up on the Internet and get all its vitals. All I can say is that when you translate that tower height to our flying field, 400 feet ain't very high.;) I've heard that on occasion the control tower has sent the sheriff's department over to the field to caution R/C flyers to fly lower. Our field is not under the usual landing pattern, but sometimes we have Cessnas coming right over us on their base leg and we start screaming "Full Scale! Full Scale!" |
ORIGINAL: rcjon If you spot a tall communications tower drive to it, if possible. The tower owner and a tower number will be on the fence. You can then use your friendly Internet and Google to find the company and the data for that tower. I found that the one behind my office is 540 feet tall. I look at it frequently and try to take that reference to the flying field. Our flying field is within a couple of miles of an airport. Purportedly, we are supposed to not fly over 400 feet (and so you know that never happens.) This has lead to several discussions at the field about how high 400 feet was. So when I'm on break behind the office I studied this communications tower that is approximately 1/4 mile from the office. One day we used a laser range finder and trigonometry to estimate a height of just over 500 feet for the tower. I didn't believe the estimate - I didn't think it could be that tall - but we rechecked the calcs - and eventually I drove over to the tower and got information from the gate that enabled me to look the tower up on the Internet and get all its vitals. All I can say is that when you translate that tower height to our flying field, 400 feet ain't very high.;) I've heard that on occasion the control tower has sent the sheriff's department over to the field to caution R/C flyers to fly lower. Our field is not under the usual landing pattern, but sometimes we have Cessnas coming right over us on their base leg and we start screaming "Full Scale! Full Scale!" |
| All times are GMT -8. The time now is 07:36 AM. |
