RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Field box plans (https://www.rcuniverse.com/forum/beginners-85/3039099-field-box-plans.html)
Orrisma 06-03-2005 01:29 PM
Field box plans
I would like to build my own field box, does anyone know of any plans on-line for one? Thanks
Al Stein 06-03-2005 02:36 PM
RE: Field box plans
But of course... Howard Sullivan's RC Flight Unlimited site has that and a whole lot more that you'll find useful.
[link=http://webpages.charter.net/rcfu/]RCFU[/link]
[link=http://webpages.charter.net/rcfu//Plan****wings/index.html]RCFU Plans and Drawings including a VERY simple field box and one to hold all of your basic field needs[/link]
Fastsky 06-03-2005 03:31 PM
RE: Field box plans
Or you could just go to Wallmart and buy a plastic tool box for arond $10.00. There are some good sized sturdy boxes for that price. They are fuel proof and don't need paint. Make a cut out in the front for the power panel. Drill out 4 holes in the upper inside tray for the feet of the starter to fit into. Mount a 12 Volt 7 AH battery and an electric fuel pump inside. I also installed a 45 oz. fuel tank inside so that I don't need to open the fuel jug very often. I wired the fuel pump into the back of the control panel so that I could control the on/off and direction from the front of the box. Mine is going on 6 years now with no problems. I have also seen a few tool boxes that are solid flat on top and act as a stool. They are a bit taller and seem to work well too. Depends what you want.:D
Rubberduck 06-03-2005 05:58 PM
RE: Field box plans
As a followup to Fastsky's post, here's the thread that I got my ideas from for my field box...
http://www.rcuniverse.com/forum/m_16.../tm.htm#167247
RhyanO 06-04-2005 10:16 AM
RE: Field box plans
YES!
The plastic tool box is definatly the way to go.
I am using one myself that I got at Sears for $11.00. Like stated above I also put the power panel on the outside, Battery, fuel pump and 40oz fuel tank inside.
I personally dont see the purpose in carrying and ENTIRE full gallon of fuel with you to the pitts every time yoiu fly. I get about 4 flights out of the 40oz tank and if I want more I usually have the gallon of fuel in the car if I need to refil the 40 oz tank.
Cheers,
Ryan
txaggie08 06-04-2005 04:17 PM
RE: Field box plans
i just built a goldberg monster tote. i dont think you could physicaly buy the lumber for what theycharge for the precut kit
Kaoma 06-05-2005 08:03 PM
RE: Field box plans
1 Attachment(s)
Here is the field box I have built recently. Its made from 6ply wood and stained yellow. Plan to keep it for life. A bit on the heavy side but its OK.
sabbadin 12-29-2013 05:29 AM
Do you have this plan for share ?
Tom Nied 12-29-2013 07:30 AM
1 Attachment(s)
I built the Great Planes Master Caddy when it was available as a kit. It turned into a project equal to any plane kit as far as time and labor was concerned. I like it but would recommend any prebuilt alternative. I spent too much time on it. As all field boxes, you will fill it up and it will get heavy. I had to build a wagon to make it easier to get from the car to the flight line.
http://www.rcuniverse.com/forum/atta...mentid=1952218
