Pinning Hinges?
Hey guys,
I've got an aweful lot of flight on y Ultra Stick Lite now and recently had to replace the rudder hinges! Can I pin them by drilling through the wood and hinge and inserting a toothpick with Woodglue or Epoxy? I could also use CA but I don't much care for it and the longer set-up times of the others are beneficial.. Thanks |
RE: Pinning Hinges?
I've been doing what you described for almost 25 years and it has never let me down. However, I never saw the need to glue the toothpicks in since the surface is going to be covered. This makes life a lot easier if I ever needed to remove that surface.
The hole I drill for the toothpicks is relatively small so the toothpick really needs to be pushed in there. Also, if in doubt, you can always use two toothpicks per side (4 for each hinge). Damon |
RE: Pinning Hinges?
Hi!
Why pin them?? It looks terrible! I have never in my 30 years in this sport/hobby lost a flyÃ*ng surface due to a hinge failing in the air. I either use 5min epoxy for ordinary hinges or for my mylar hinges... Flash thin CA glue + kicker. This is on all kinds of models, large aerobatic birds to 375km/h F3D pylonracers. Regards! Jan K Sweden |
RE: Pinning Hinges?
1 Attachment(s)
I don't know why he said that they look terrible? If done properly they can't be seen. Drill a hole, insert a toothpick or small dowel, cut off and sand smooth. If you feel you want to pin your hinges there is nothing wrong with doing that at all
Ken |
RE: Pinning Hinges?
OK thanks guys! I Guess I'll be pinning them tonight!
RE: Pinning Hinges?
RC ken
I think it is a she:D |
RE: Pinning Hinges?
ORIGINAL: Pilot Chad RC ken I think it is a she:D |
RE: Pinning Hinges?
Pinning Tips, don't use CA for pinning. If you slow down while inserting the ttohpick, the glue will suddenly set wheather it is in far enough or not! Wood glue works the best for this. Use the round tooth picks and cut them in half. Drill a small hole through the hinge. Add wood glue to the tooth pick and insert it with the pointy end until the middle of the toothpick that you just cut is level with the outside of the control surface. Now when the glue drys you only have one side to sand level instead of 2 sides! BTW unless you are using the giant scale hinges, I find that 1 pin for each side of the hinge is adequte.[8D]
RE: Pinning Hinges?
At his age he probably doesnt understand that MEN can have the name of Jan
RE: Pinning Hinges?
ORIGINAL: ICE_MAN Hey guys, I've got an aweful lot of flight on y Ultra Stick Lite now and recently had to replace the rudder hinges! Can I pin them by drilling through the wood and hinge and inserting a toothpick with Woodglue or Epoxy? I could also use CA but I don't much care for it and the longer set-up times of the others are beneficial.. Thanks http://www.rcuniverse.com/forum/m_15..._2/key_/tm.htm Post #45 and 46 Works great, hasn't failed in 25+ years Don |
RE: Pinning Hinges?
tsands,
I have never known any one with the name jan that was man. Would rather be able to not know stuff because of my age, then to not be able to exercise because of my age ;-) |
RE: Pinning Hinges?
ORIGINAL: jaka Hi! Why pin them?? It looks terrible! I have never in my 30 years in this sport/hobby lost a flyÃ*ng surface due to a hinge failing in the air. Jan K Sweden I used the large Sig flat hinges on the ailerons, didn't glue them, but used two pins per side, they're doing fine. |
RE: Pinning Hinges?
Chad man,
That doesn't make since. And there are plenty of guys with female names and girls with guy names. You ever heard of Wilma Newberry? I fly with HIM sometimes and he just happens to be a former C/L Champion according to his family. My dads names Courtney, not uncommon.. So what's wrong with Jan? |
RE: Pinning Hinges?
I'm sorry for assuming?
RE: Pinning Hinges?
I guess you had to be European to fully enjoy the he/she debate here. Jan is a common male name in Germany/Nordic countries
| All times are GMT -8. The time now is 09:47 AM. |
