RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Evolution .61 (https://www.rcuniverse.com/forum/beginners-85/3202744-evolution-61-a.html)
khart2000 07-26-2005 05:25 PM
Evolution .61
Any problems associated in mounting an Evolution .61 inverted? Does the remote needle valve get relocated to the bottom (inverted top) of the casing? Thanks for your help.
khart
Lowlevlflyer 07-26-2005 05:35 PM
RE: Evolution .61
I think the remote needle valve can be mounted where ever you need it.
Fastsky 07-26-2005 06:25 PM
RE: Evolution .61
Mounting any 2 stroke engine isn't recomended. The engine is pretty hard to start unless the plane is inverted making the engine upright. Also in most cases the fuel tank is higher than the carb and this causes the fuel to siphon into the engine. When that happens the fuel douses the glow plug and the engine quits. If you must do this, an on board glow plug driver helps. 4 strokes have a different design and aren't as bothered by inverted running. [8D]
britbrat 07-27-2005 10:09 AM
RE: Evolution .61
ORIGINAL: Fastsky
Here we go again. There should be no significant problems in mounting your engine inverted. The Evo is no different than a host of other 2-strokes that work just fine when inverted -- just get the fuel tank height correct & there should be no problems. I have several inverted 2-stroke setups & I don't use an on-board glo-driver -- they work flawlessly.
bruce88123 07-27-2005 10:20 AM
RE: Evolution .61
In the interest of saving all of the typing and arguing again, just try reading this thread and go from there. OK?
http://www.rcuniverse.com/forum/m_31..._1/key_/tm.htm
both sides are stated several times.
BTW - I agree with Britbrat on this one.
Fastsky 07-28-2005 09:41 PM
RE: Evolution .61
Re: "- just get the fuel tank height correct & there should be no problems. "< thats not very easy to do on a lot of models! [>:]
