Need help mounting engine mount
I'm putting a new engine on my Twist, and can't find a mount that lines up with the stock blind nuts(old mount is on different plane). They are all about 1/8-1/4" off.
How should I mount this? I thought about re-drilling two new holes, but wasn't sure about the 1/8-1/4" extra. Should I fill the holes with epoxy, and then drill, or epoxy on a piece of ply to the firewall? Any ideas? |
RE: Need help mounting engine mount
Hi Backwing,
If it were me I would plug the old holes with dowels and epoxy. Let it dry, then redrill for the new mount. You could also use JB weld to fill the holes. Darren |
Dowels and epoxy is the simplest method.
Bill |
You can redrill the firewall or redrill the mount. Either way will work well. Plug the original holes in the firewall with dowels and CA.
Dr.1 |
I've got to agree with the above. Use dowel rods to fill the old holes in, and then redrill the firewall for your new engine mount.
Ken |
Dowels... Why didn't I think of that:)
Thanks. |
| All times are GMT -8. The time now is 11:19 PM. |
