RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Carburators... (https://www.rcuniverse.com/forum/beginners-85/3503388-carburators.html)
IBrakeForNobody 10-30-2005 12:20 AM
Carburators...
I recently noticed something, why do all glow airplane engines have rotary carburetors and not slide-valve carbs? I'm thinking rotary carbs would be easier to control in a airplane than a slide valve carb.
Thank you
The Ghost 10-30-2005 12:54 AM
RE: Carburators...
Not all, I have a couple of OPS 45's that have slide carbys, rear rotor race engines.
Cheers
Dr1Driver 10-30-2005 10:11 AM
RE: Carburators...
The Webra Dynamix is a slide-valve carburetor that has been around for a long time. It's a little tricky to adjust, but provides excellent response. I suspect rotary barrel carbs are easier to manufacture.
Dr.1
sbd-5 10-30-2005 12:59 PM
RE: Carburators...
hp also uaes a slide valve carb in the gold cup 2 strokes.rotary barrel carbs are also cheaper to make..the webra dynamix was designed for use with a pumop,offers a larger intake than the tn carb
JohnBuckner 10-31-2005 09:22 AM
RE: Carburators...
The reason rotary barrel carbs have been so successful and almost universal in our applications is the fact that this type is easily made to not only provide not only rotary motion for throttle control but also provide easy in an out (longtitudinal) movement for simple and effective double needle midrange control.
John
