RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Airplane storage hanger? (https://www.rcuniverse.com/forum/beginners-85/3575652-airplane-storage-hanger.html)
tvhelidad 11-21-2005 10:22 PM
OK Now I have 2 planes and a heli. I have to clear the planes off the floor so they dont get stepped on. I have a duraplane aerobat 40 and a spad that is the same size. I remember seeing a design for a storage system where you hang the plane and wing goes behind it.
aeajr 11-22-2005 04:11 AM
RE: Airplane storage hanger?
Check www.towerhobbies.com or www.hobby-lobby.com for plane hangers.
tr21triton 11-22-2005 10:10 AM
go to home depot and get the metal double slotted shelf hangers that you screw to the wall.you can cut it whatever length you want.get the long shelf supports and use a piece of foam pipe insulation on it to protect the plane.we get 5 planes on a 8ft section.
tvhelidad 11-22-2005 11:33 AM
Just got back from HD. I bought a 1/2 sheet of drywall and 4 white shefl brackets and 4" L,s . I willpost a pix when done. total cost
$9.09
coolbean 11-22-2005 04:32 PM
I have an unfinished basement. I screwed 2 2x4's 5 feet long hanging down from the rafters about 4 feet apart. Then drilled holes 1/2 in diameter about 2 inches deep. First three sets one foot apart, last set two feet apart. Then push 1/2 inch dowell rods, about 2 1/2 to 3 feet long into the holes. Get some type of foam product, I used foam tape used to seal doors, and cover the top side of the dowels.
First three slots hold wings, last slot holds fuses.
I used all scrap wood, the foam tape cost less than $2.00
tvhelidad 11-22-2005 04:38 PM
Nice. Thats better then what I'm doing. For now just going to hang some 4 ft X17" shelves on the wall
tvhelidad 11-22-2005 09:35 PM
OK I took coolbean's advice. Went back to HD returned my stuff for new stuff. I will try to post a pix. The dowels are the way to go.OK the picture is in my gallery on this forum I dont know how to paste it in this message. I could link to my website but I havent fooled with it on a while.;)
Digger44 11-22-2005 10:23 PM
1 Attachment(s)
Here it is.[8D]
tvhelidad 11-22-2005 10:34 PM
Thanks Digger44 . How'd you do it?
Digger44 11-23-2005 12:47 PM
When you hit the post reply button at the bottom of the page, the reply to message box pops up. Right below the text entry box on the left hand side there is a link that says Click here to upload! Then you get another box that you can select files from your harddrive with.
Glen Wearden 11-23-2005 03:11 PM
My shop has exposed ceiling joists, so I just make a loop out of old macrame rope for the front and back, and suspend the planes that way. The rope is soft and won't mar the plane in any way. Glen
tvhelidad 11-24-2005 12:09 AM
1 Attachment(s)
Thanks digger 44. Happy Turkey day Here's a pix of my Quick 50 that I want to fly someday when the temp goes beyond 45!!
