master caddy
Hey! I am wondering if anyone knows the dimensions for the battery compartment of the master caddy. I want to know if my motocycle battery will fit before I make the purchase. Thanks if anyone can help me out.
Shane |
RE: master caddy
1 Attachment(s)
I didnt measure mine, but there is a ton of room in the battery compartment of a Master Caddy. A Motorcycle battery should fit easily!
RE: master caddy
Front to back approx 13.7cm (bottom)
bottom to top is approx 15.3cm width is around 19.5cm it's tapered at the top just below the starter housing down to around 10.7cm Good luck |
RE: master caddy
im just a little short, my battery is 17CM high.
RE: master caddy
A new battery really doesn't cost very much![sm=idea.gif]
http://www2.towerhobbies.com/cgi-bin...?&I=LXL370&P=0 There are even less expensive choices as well. Mark |
RE: master caddy
That battery doesn't last too long at all. A few months and mine was shot and it looses its umph really quick. 3 Or 4 good blasts with the starter and its gone
RE: master caddy
ORIGINAL: aerobatixkid That battery doesn't last too long at all. A few months and mine was shot and it looses its umph really quick. 3 Or 4 good blasts with the starter and its gone |
RE: master caddy
Thats funny, maybe the cold temps up here had somthing to do with it. I had to charge mine all the time cause I flew everyday, all day long, for a few weeks and I fly up to 1.50 size.
RE: master caddy
I still haven't charged mine yet:) Still going strong too. If you have a Walmart up there you might try a different motorcycle battery, they have some smaller ones that I think will fit. ( I have the Master-caddy too) I've seen some M/C batteries at Walmart that are pretty inexpensive, don't know if they're any good or not. Good Luck.
Mark |
RE: master caddy
Same here. I have had mine 2 years and I only charge it 3 times a season. But, my biggest engine is a .91fx.
| All times are GMT -8. The time now is 05:46 AM. |
