RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Cordless starter (https://www.rcuniverse.com/forum/beginners-85/4160892-cordless-starter.html)
Kman1971 04-13-2006 12:21 PM
Cordless starter
Is there any where you can buy a cordless starter other than making your own bye tapeing a battery to the bottom? thanks Kieth
bruce88123 04-13-2006 12:32 PM
RE: Cordless starter
Doesn't get much easier than this:
http://www2.towerhobbies.com/cgi-bin/wti0161p?&I=LZ0858
Kman1971 04-13-2006 12:34 PM
just what i was looking for thanku very much:)
KW_Counter 04-13-2006 02:13 PM
Personally, I think the Sullivan is a better unit.
KW_Counter
staggerwing 04-13-2006 02:21 PM
I agree with KW Counter. I have the Sullivan Dynatron starter with the Sullivan battery pack. I have 3300 mha NiCds in it, making 14.4 volts, not just 12, and I can start everything up to my 4.8 ci Brison twin. Might cost a bit more in the short run but definitely worth it in the long run.
Rich
Wyoming Wind Festival Jan 1 to Dec 31
bruce88123 04-13-2006 02:38 PM
http://www2.towerhobbies.com/cgi-bin...?&I=LXFT85&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXFT88&P=M
I was trying to keep the cost down a bit. This is a better (higher torque) unit.
ballgunner 04-13-2006 02:46 PM
Look under starters at Tower or Omni models for Helimax & rechargeable battery packs. Two 1500 mAh 6 cell packs.
Starter $34.99 - battery packs $29.99. Very handy and very powerful. Much better than the Tower self contained.
bruce88123 04-13-2006 03:07 PM
battery packs $29.99. EACH
2 REQUIRED, batteries must be charged separately or second charger purchased.
This brings price to @ $95.
I've used one and found it uncomfortable to use. Others liked it.
MannyEdge 04-13-2006 04:09 PM
Look at this starter. I just purchased it. It started up DA-50. http://www.centralhobbies.com/Electr...rs/pwrtrk.html
Worth every penny!!!
Just my $.02 worth.
bruce88123 04-13-2006 04:26 PM
Seems to be the same as the Helimax but at a better price.
redfox435cat 04-13-2006 06:40 PM
I used this for a couple year and they work good on engine's 60 or less. I could pull over 1.00's but could only do it two or three times. I eveually had to just strap a battery to the bottom
bruce88123 04-14-2006 07:51 AM
Redfox, used what?
MikeEast 04-14-2006 08:11 AM
These are some of the best out there. Compact, Self contained, reliable, easy to use and absolutely fantastic service. The total cost is about $125 but you get the starter/batery and charger... and the service.
http://bpassociates.homestead.com/bp.html
Max and Todd Blose are super nice guys and their starters are used by pilots all over the US. I have the magnum version for my YS 1.60.
The regular and kavan will easily start anything up to a 1.40 at least.
They could start my 1.60, but only after it had been run the 1st time.
The black one above from Central Hobbies is a good one as well. It uses a couple of the RC truck batteries for power. It too is compact and powerful.
Cyclic Hardover 04-14-2006 08:17 AM
I have the big hobbico battery attached to my starter using a couple "BIG" wire ties. I cut the cord from the starter and attached some different connnectors for the battery. Been using that design for years.
I know they make special battery pack sets for this but they don't seem to have the "????" to turn over a healthy engine.
Kman1971 04-14-2006 09:36 AM
Thanku all for th replies..i didnt really know there were that many options out there...guess i have some thinking to do...the biggest engine i run at this time is an o.s 91 4 stroke but i am sure that will change eventually:D Kieth
bruce88123 04-14-2006 10:01 AM
Well, that first one I listed would definitely be marginal for that size motor.IMO
elenasgrumpy 04-14-2006 10:13 AM
ORIGINAL: MannyEdge
Just my $.02 worth.
That's looks like a pretty good one for the price if it is as powerfull as they claim it is. If not I guess you could allways use it to rob a bank.:D
KidEpoxy 04-14-2006 10:15 AM
I ran a 60size (IIR?) Magnum starter to start a .42 and a .52fourstroke
but I used just 8 cell 9.6v nominal electric airplane batts, cp1300 shorties
Just lettin ya'll know that even underpowered with 9.6v Lil'Batts, it will do a .40 class engine fine
JohnBuckner 04-14-2006 10:40 AM
1 Attachment(s)
I couple of folks above indicated that voltage is what is needed for a really effective portable unit and I could not agree more up to about 1.20 displacement.
This is the cheapest hobbico or tower or whatever starter avalible with very simple holders and powered by two 3000 Nimh seven cell sticks. This provides 16.8 volts in series that results in much higher RPM that is far more effective than any other up to about 1.20.
Each stick pack was twenty bucks with its own wal wart from a supplier for paint guns. The additional voltage is no problem for the motor itself.
There is one serious disadvantage for this one and that is the fact that it is always vanishing and I have to go looking for it at the field, everyone wants to use it as their wimpy 12v portables die out.
If I ever feel the need for the big two or four strokes over 120 then I,ll just put one together with a geared motor.
John
elenasgrumpy 04-14-2006 11:14 AM
Hey John, That is a nice looking set up. Mind if I borrow that for a minute?:)
MannyEdge 04-14-2006 11:50 AM
ORIGINAL: elenasgrumpy
ORIGINAL: MannyEdge
Just my $.02 worth.
Thanks for the idea. I might have to use that idea because this hobby is draining my wallet.[sm=drowning.gif]
JohnBuckner 04-14-2006 01:03 PM
1 Attachment(s)
He, he - be my guest, just don,t make me come a lookin fer Ya when I need it, cause by the time I find Ya in my wheelchair I get "grumpy" too:D
http://www.batteryspace.com/index.as...ROD&ProdID=374
John[8D]
redfox435cat 04-14-2006 06:43 PM
1 Attachment(s)
the hobbyco power core pack MK2 listed above that bolts to the bottom of most starters
Redfox, used what?
MikeEast 04-14-2006 07:20 PM
lol,,, redfox's is EXACTLY what I had down to the yellow zipties before I got my BP starter.... It works great on anything up to about 1.2 or a well broken in 1.4...
ballgunner 04-15-2006 01:11 PM
The Kavan starter and batteries may be a bit expensive but it is the best I've ever seen. Other than the high cost of the batteries it really does the work.
