RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   glow starter (https://www.rcuniverse.com/forum/beginners-85/4228426-glow-starter.html)
mechanic boy 05-01-2006 03:36 PM
glow starter
hey there i need some help. does any body know how to make a homemade glow clip that would fit on a cox 0.49 sure start
red head 05-01-2006 03:52 PM
RE: glow starter
Use alligator clips !! ENJOY !!! RED
Missileman 05-01-2006 04:06 PM
RE: glow starter
FYI, one of the clips (usually negative black clip) can attach anywhere on the motor and , of course, the other one attaches to the tip of the glow plug.
mechanic boy 05-01-2006 04:44 PM
RE: glow starter
thanks what battery do i need
Missileman 05-01-2006 04:55 PM
RE: glow starter
D size 1.2 volt
mechanic boy 05-01-2006 05:09 PM
RE: glow starter
how long should it take to heat
bigtim 05-01-2006 05:19 PM
RE: glow starter
should be instantly hot . COX should still make their glow plug clip, thats what we always used for our .049 planes. clips work fine in a pinch though.
mechanic boy 05-01-2006 05:28 PM
RE: glow starter
1 Attachment(s)
well it dosent maybe that the battery is low
mechanic boy 05-01-2006 05:54 PM
RE: glow starter
how hot or just warm because mine just gets warm or maybe that i need a new battery
piper_chuck 05-01-2006 06:53 PM
RE: glow starter
ORIGINAL: mechanic boy
It should glow an orange color. "Heavy duty" batteries are about the weakest out there. Pick up something like one of these: http://www2.towerhobbies.com/cgi-bin...&I=LXL368&P=ML , it will last much longer. Note, I just showed that one as an example. You should be able to find one locally at a dept store.
Missileman 05-01-2006 06:57 PM
RE: glow starter
ORIGINAL: piper_chuck
Make sure it is the 1.5 volt and not 6 volt lantern battery. A lantern battery will fry that glow plug faster than you can order a new one.
mechanic boy 05-01-2006 06:58 PM
RE: glow starter
ok well im new to this and what part should glow orange
piper_chuck 05-01-2006 07:44 PM
RE: glow starter
There's a little wire inside that's coiled like a spring. This should glow.
Missileman 05-01-2006 07:49 PM
RE: glow starter
On that Cox motor there is an open port in the side. if you look inside, with the piston down out of the way, you will see a bright glow inside. It will look alot like a car cigarette lighter.
mechanic boy 05-01-2006 08:48 PM
RE: glow starter
thanks everyone
