compatible engines for the nexstar
I've just ordered a Nexstar ARF.
What engines other than the O.S. 46 FXi will fit without adding shims, changing the engine mount or adding an exhaust extension?Wondering what my options are. |
RE: compatible engines for the nexstar
Not sure about others but the OS 46 AX should work without shimming etc, but any 40-46 2 stroke engine will work.
I thought any 40-46 should fit then I read this little addendum on http://www2.towerhobbies.com/cgi-bin...&I=LXJDH3&P=RO
*Because the .46LA dimensions are different than a bearinged engine, it will not work in this plane unless modifications are made. You will need a different engine mount. Depending on which engine mount is used, you may need to add aprox. 1/4" to 3/8" plywood to the firewall to extend the prop forward enough to keep it from contacting the fuselage. If a Tower .46 is being use, you will need to use an muffler extension. The Dubro 699 Muffler Extension DUBG1319 will work fine. |
I've got an OS-50SX in mine and it dropped right into the "Iso-mount" system Hobbico supplies with the model.
I don't think and 40 to 50 size engine would be a problem even if some modifications were required. If you can't or won't deal with them I would suggest you stick with what Hobbico recommends. Best of luck. Bruce |
the 46 works well with this airframe a 40 might be a bit under powered if you are going any where go up in size for sure a 50 or a 4 stroke like a 70 or so
This ones might fit:
Evolution 46NT Evolution 40NT Webra Speed 55GT (Might be too much :D) Saito 56 GMS 40 GMS 47 Magnum 46 OS 40 LA/FX OS 46 LA/AX OS 50 SX SuperTigre GS40 SuperTigre GS-45 SuperTigre G-51 Tower Hobbies 46 Thunder Tiger 42 Thunder Tiger 40 Thunder Tiger 46 Magnum 52 FS |
You have one for sale on page one SK50A will bolt rite on Check with Virgina at www.kangkeusa.com $59.77 $10.00 more for remote needle I read a report on it and its my next motor
| All times are GMT -8. The time now is 05:59 PM. |
