RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   My LT40 wont turn! (https://www.rcuniverse.com/forum/beginners-85/425575-my-lt40-wont-turn.html)
ctdahle 12-19-2002 04:31 AM
My LT40 wont turn!
Make sure you have gutsy enough servos to swing those big ailerons around.
Rip out the torque rods and install a servo for each aileron.
Set up the flaperon mix to give you a bit of aileron reflex instead of messing with the angle of attack of the wing.
There is not a reason in the world why a properly set up LT-40 can't loop, roll and make as quick of a high G turn as you want.
Woodsy 12-19-2002 10:38 AM
My LT40 wont turn!
The LT40 is a basic trainer it should roll and loop fine if the deflections and CG are OK.
Check the Cg and deflections are as they should be and go fly, it's not a performance wizard so dont expect it to perform like one
Dogz 12-19-2002 10:57 PM
My LT40 wont turn!
Sealed the gap and it does fly a lot better.
I'm having a ball, I love how you can hover on the propeler and when the plane tumbles it seem to allways fall the right way up like a cat landing on the ground.
Live Wire 12-21-2002 06:16 AM
My LT40 wont turn!
THANKS 51 FINGER IN FOWARD MIND IN REAVERSE
