RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Hitek HFD-08RD receiver question (https://www.rcuniverse.com/forum/beginners-85/4455299-hitek-hfd-08rd-receiver-question.html)
flynte 07-02-2006 02:53 PM
1 Attachment(s)
I was wiring in the servos and batteryto the rx, but the connectors can go in both ways. So does the signal wire go the out side or inside of the receiver???? This is my first hitek flight pack, my other plane has futuba and they only go in one way.
any help appreciated.
flynte
Mr67Stang 07-02-2006 03:09 PM
RE: Hitek HFD-08RD receiver question
Look at the battery input slot. There apears to only be two prongs. So plug that in to have bothe wires contact then match up the servo wires so there power +/- leads match the battery. In the picture it looks like the signal lead will be to the outside.
flynte 07-02-2006 03:35 PM
unfortuantly the battery slot is also ch8 so there is 3 connectors in there. Went to hitek site and they show nothing either.
I have another futuba flight pack so I guess I'll strip all the hitek out, and send it back, and go stick with futuba.
thanks
flynte
Mr67Stang 07-02-2006 03:47 PM
Okay you can also try setting it up just like your Futaba. make them all match and if it does not work reverse them. I have installed them backwards on my hitech micro receiver and had to reverse them with no damage due to the positive lead being in the middle the ground and signal are the only thing to get reversed.
Campy 07-02-2006 03:58 PM
Install the DARK wire (typically black or brown ) to the OUTSIDE edge of the case (just like in a Futaba - dark wire to the outside of the case )
RCKen 07-02-2006 04:20 PM
1 Attachment(s)
Here is a wiring diagram that will show you the proper wiring for all the major brands. This shows the servos, but you can translate that to your receiver.
Hope this helps
Ken
flynte 07-03-2006 10:44 AM
Thanks for the replies, yes the signal wire does go to the inside.
flynte
