Ultimate goldberg powered by 3W24i
Hello all!
Someone have already used (or saw) a Ultimate powered by a 3w24i? What do you think? Is it possible? Is it a good option? Tanks. |
RE: Ultimate goldberg powered by 3W24i
That would be a lot of extra weight in the nose. I built mine with a saito 1.25 which weighs around 1.5 lbs. with the muffler. I think the 3W weighs in around 3 lbs which would probably require a lot of weight in the tail.
I'm guessing your overall weight would come in around 11 lbs. which would be a bit heavy for the airframe in my opinion. I would be curious to see how it turned out if someone did do it. |
This guy might be able to answer that question.
[email protected] from http://www.cactusaviation.com/index.html |
| All times are GMT -8. The time now is 01:08 PM. |
